91 HF rex, MFR location-Need help asap. Thanks
Hey guys whats up. Ok so I need to fix my main fuel relay.
SOmetimes the fuel pump comes on and sometimes not. fuses are alol good and new.
and I know this is a commen problem after 15 years etc.....
Where the explitive is it? I cant find it. I know what it looks like. Replaced them before on my 90 integra and I just cant seem to find this.
Please let me know asap!!!!
Thanks, Jose
Thanks, Jose
Bump I need to know.
I know what it looks like. But for some reason cant find it. I took off the fuse panel but dont see it. do I need to take off the other intr peice?
this is a 91 crx hf. used to my da9.
Thanks!
Thanks!
I need the location of the Main fuel relay......
LOCATION.
Thanks you.
Edit: well I guess I can go look again (drive to friends house)
But if anyone knows off the top of their head the exact location. thats would be awsome!
I know it locaed under the dash below the cluster area.
This I know. Exactly where on this 91 crs hf is something I dont know.
Thanks
LOCATION.
Thanks you.
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I CRX I »</TD></TR><TR><TD CLASS="quote">should be above the hood latch under the dash or in that area some where</TD></TR></TABLE>
he's right... u gotta turn ur head in ways u dont want to, + i need plenty of light
ok thanks. Yeah i removed the fuse panel, and layed on my back as if I was sitting in the seat with my head down near the pedals.
Well I'll go see if I can find it. thanks.
if your planning on checking it out i wouldnt follow the instructions from the manual above i just put that there for reference to where it is cuz checking their way wont show a intermittent problem.
you best bet is to open the relay and resolder the points.
this should help you out abit http://www.integra.orcon.net.nz/relay
i resolderd mine and havent had a problem since
well I went and found it. just like the pic above, that **** is packed in there.
I was like, damn holy shiet. Glad i picked up the MFR's from junkyards saved me $65 tonight.
FIXED the problem 100% like I said.
THANKS for the information guys.
editz: yeah also all 4 of my relays are not red. :shrugs:
Just crack open your bad one and resolder all the points on it. Fixes them every time. My $100 beater would NEVER start until I fixed the main relay. It's been a year and over 10,000 miles and it hasn't failed me once. This is the third one that I've fixed this way. Just open the lid on the relay and freshen up all the solder points with some new flux and solder. Put the lid back on and slap it back in the car. Done.
