Corner Weighting
Old Dec 13, 2006 | 08:06 AM
BlueR's Avatar
Default Corner Weighting
i had my car corner weighted and these are the figures:
With 165lb Driver and 1/2 tank of gas
LF= 863 RF= 801
LR=538 RR= 478
Cross Differential
RF/LR= 1341
LF/RR= 1339
total weight with 165lb driver and 1/2 tank of gas= 2680 lb
how do i interpret these numbers?
are these numbers optimal?
because i'm not sure theres much more that can be done
Old Dec 13, 2006 | 08:20 AM
kepani's Avatar
Default Re: Corner Weighting (BlueR)
only thing to do is lose weight from the driver! but that means you'll have to go back again...
numbers look awesome!
kepani
Old Dec 13, 2006 | 08:31 AM
EleanoR's Avatar
Default Re: Corner Weighting (kepani)
those numbers look quite good Marc. your cross weights are right on (within 2 lbs).
Old Dec 13, 2006 | 08:32 AM
RTW DC2R's Avatar
how do you make adjustments??
Old Dec 13, 2006 | 08:39 AM
walker111's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">how do you make adjustments??</TD></TR></TABLE>
Suspension
Old Dec 13, 2006 | 08:40 AM
white rocket's Avatar
Good info. I am very interested in corner weighing my car next year.
Old Dec 13, 2006 | 08:41 AM
GUILOTINE's Avatar
Kill Gil
Default Re: (walker111)
man I would ruin any corner weighting with my fat ***
Old Dec 13, 2006 | 08:42 AM
baonest's Avatar
more
Old Dec 13, 2006 | 08:44 AM
RTW DC2R's Avatar
no I mean what if the numbers are totally screwed up, how do you correct/adjust it?
Old Dec 13, 2006 | 08:45 AM
baonest's Avatar
AFAIK, tune the suspension, tire pressures....
but if they are way off, then i dont have a clue.
Old Dec 13, 2006 | 08:52 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">no I mean what if the numbers are totally screwed up, how do you correct/adjust it?</TD></TR></TABLE>
I believe you raise/lower the suspension at each corner to even out the weights.
Old Dec 13, 2006 | 08:53 AM
BlueR's Avatar
Default Re: (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">I believe you raise/lower the suspension at each corner to even out the weights.</TD></TR></TABLE>
thats all that was done with my car to get to where i am at currently
Old Dec 13, 2006 | 08:54 AM
RTW DC2R's Avatar
and what is the objective? to be even at all corners? or side to side? or diagonally?
Old Dec 13, 2006 | 08:56 AM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">and what is the objective? to be even at all corners? or side to side? or diagonally?</TD></TR></TABLE>
thats what i would like to know also
Old Dec 13, 2006 | 08:57 AM
walker111's Avatar
My bust, I'm swamped at work today.
I was trying t osay what everyone else just said. Tuning the sussy, lowering/raising to get the ideal results. If you cant do it that way.....your car is fucked
RTW DC2R's Avatar
I have a feeling my car's numbers would be so F'ed up lol
what about spring rates and dampening rates, how do they come into play when corner weighting?
Old Dec 13, 2006 | 08:58 AM
walker111's Avatar
It would be easily fixed with a good sus..
Old Dec 13, 2006 | 09:18 AM
Willard's Avatar
nothing to add... but my numbers.
https://honda-tech.com/zerothread?id=1185665
Old Dec 13, 2006 | 09:28 AM
tartje's Avatar
Default Re: Corner Weighting (Willard)
all corner weighting is, is balancing out the pressure each tyre exerts on the road as evenly as possible from side to side on the car, so the handling is more balanced
mine was done recently, with me sat in it, it came up 50/50 laterally and 60/40 front rear. felt beautiful after it was done
and totaly car wieight was 1111kg or 2449.33lb's
Old Dec 13, 2006 | 09:32 AM
BlueR's Avatar
so the key is to get the cross-weights to = 50/50?
Old Dec 13, 2006 | 09:36 AM
R you serious's Avatar
post this in the RR/auto X forum. Those guys are quite helpful when it comes to this marc
Old Dec 13, 2006 | 09:38 AM
tartje's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">so the key is to get the cross-weights to = 50/50?
yup, get it as balanced as possible
Old Dec 13, 2006 | 09:39 AM
BlueR's Avatar
Default Re: Corner Weighting (R you serious)
i know
but i am kinda trying to have a discussion in here first so that the ITR members would be able to discuss and benefit
if it fails, RR/XX it is
Old Dec 13, 2006 | 09:46 AM
Relic1's Avatar
one of the most overlooked things when people install coilovers.
decreased acceleration/braking/cornering all in one 'upgrade'.
an excellent write up about it... http://www.grmotorsports.com/n...s.php
OP: great numbers
Old Dec 13, 2006 | 12:39 PM
Flux's Avatar
Yes, you are trying to get the diagonal weights as close as possible. You cannot impact the F-&gt;R weights by adjusting your suspension, this has to be done by physically moving weight in the car.
Good numbers.
