2006 lx 4 door possible caliper problem ???
so i just started hearing some loud noises from my driverside front tire when i would brake, kinda like a louder ABS noise, and i have 19000 miles on the car already. so i figured i will just buy new pads incase i see i need to have the rotors cut and what not.
so when i took the pads out, to remove the rotors i noticed that the driver side pads where worn down all the way, and the passenger side still has about another 10k miles left on it.
what do you think honda-tech ?? time for a dealer inspection ? i would have to wait a while now since i already changed the pads and put new ones on no ??
Thanks in advance !!
k, thanks thanks.
i have to check to see if i have the original pads still. if not i can tell them what happened but they would need some kind of proof, before they replace anything no ?? im sorry i have never been to the dealer unless for buying parts for my turbo hatch.
THANKS !!!
THANKS !!!
Yeap... You screwed yourself over by replacing those brake pads.. If I see a car like that and then new brake pads and wrench marks.. I'd say something fishy is going on and deny any warranty claims.
do you do alot of late braking or some thing ? cause that much milleage and the brakes are done or getting low as well..... cause late braking cause pad to wear faster...
Dogginator
10
Sep 1, 2005 09:09 PM
