Does anyone have a Fuel Pressure Gauge mounted on the fuel filter?
if you do, what fitting did you use to get it to screw into the pressure relief bolt hole? i have an NOS liquid filled Fuel Pressure Gauge that i want to mount there. it's fitting is a little bigger than the pressure relief bolt.
I have the B&M also. The necessary fitting came with the gauge in a kit - http://store.summitracing.com/defaul...rchType%3DBoth . The size of the fitting is not listed, but I imagine if you call Summit, someone would be able to tell you. Or even send an e-mail to B&M @ their site - http://www.bmracing.com/ , asking them what the size of the fitting is that they put in their kits. But then, if you're NOS gauge is a different size, none of this will help...
First you cant get a fitting that small. the relief hole is only 6mm. What kind of guage kit is it? I used a B&M it fit cherry, came with a new banjo bolt with the correct size hole to accept the guage.
