link for lsvtec??
Old May 11, 2002 | 04:33 PM
AudioXtremes's Avatar
Default link for lsvtec??
does anyone have a link on how to do the oil lines for lsvtec?
Old May 11, 2002 | 06:03 PM
rioninja's Avatar
Default Re: link for lsvtec?? (AudioXtremes)
i have an oil line for sale, $50.00
Old May 12, 2002 | 02:19 AM
sparkz's Avatar
the parts i used are:
about 2' of stainless steel lines
-4an straight fitting
45 degrees -4an fitting
1/8" tee
3/8" to -4an fitting
-4an to 1/8" fitting
Old May 12, 2002 | 07:27 AM
Default Re: link for lsvtec?? (sparkz)
does anyone have a tutorial on how to do it? i know you have to change oil passages but i have never seen it. i am about to go pick up a crx with a b16 with a bad block. should i just get another b16 block or do the lsvtec???
Old May 12, 2002 | 09:16 PM
EF_LSVtec's Avatar
Check out this site... http://www.c-speedracing.com/howto/lsvtec/lsvtec.html
If you're choosing between a B16A or LS/Vtec set up...there's a few tradeoffs. Stock vs stock, LS/Vtec is stronger but will compromise reliability. It all depends how you run and take care of your engine though. But there's a reason why honda makers made the B16 and B18's...why one has a longer stroke compared to the other, why one has vtec and none for the other. Mixing them together, although possible I'm sure will have some drawbacks. Are you willing to take em?
92DAB16A
Jan 20, 2012 10:45 PM
Bartonsonline
Dec 16, 2010 05:40 PM
b16-bomber
Nov 8, 2006 05:56 PM
Big Dick Bandit
Sep 4, 2003 12:02 PM
WAFFLES
Jul 20, 2001 02:23 PM
