EGR valve has vacuum at idle???
Old Dec 12, 2006 | 10:09 PM
BuddhaSiR's Avatar
Default EGR valve has vacuum at idle???
96 accord LX. When i first start this car no vacuum at idle to EGR valve as it should be. The problem starts after i drive it and then come to a stop. When driving/cruising the EGR valve is going to have vacuum to it but shouldnt when i come to a stop but it does. My question is what bleeds off the vacuum when the car comes to a stop and is at idle? Anyone ever had this problem before?
here is a link to a picture of the components in question
http://www.hondaautomotivepart...EVICE
Item #1 is a vacuum control valve, that has to be what bleeds off the vacuum.
from what i understand item #2, the solenoid simply allows or blocks vacuum going to the EGR valve or is it the solenoid the bleeds the vacuum?
I know Toyotas bleeds it off at the solenoid. Maybe Honda is the same way.
Modified by BuddhaSiR at 11:21 PM 12/12/2006
Modified by BuddhaSiR at 11:24 PM 12/12/2006
Old Dec 13, 2006 | 05:52 AM
hondadude's Avatar
Default Re: EGR valve has vacuum at idle??? (BuddhaSiR)
That orfice was always a problem in the older 86-89 LXi accords, you should be able to pass some air thru the egr vacum line with the engine off. If not backtrack the line to the solenoid and shoot some brake clean and compressed air thru it. Carb cleaner is not a good idea, too harsh for the plastics.
Old Dec 14, 2006 | 12:30 PM
BuddhaSiR's Avatar
Default Re: EGR valve has vacuum at idle??? (hondadude)
well i figured out what happened. it does bleed off at the vacuum solenoid. the problem was the vacuum lines were backwards. The vacuum line going from the egr to the solenoid is suppose to be on the top port. I had it on the bottom. No more vacuum at idle, car doesnt bog down and die anymore. Hope this helps someone trying to figure this out in the future. Check your vacuum routings!!!
Old Dec 17, 2006 | 11:49 PM
PnX-R's Avatar
If you want to help people with 96 accords and EGR problems, just tell them to go to the dealer, Honda has an extended warranty and will replace anything that turns on the check engine light for a certain list of vehicles..
Old Dec 18, 2006 | 09:07 PM
BuddhaSiR's Avatar
Default Re: EGR valve has vacuum at idle??? (PnX-R)
Yeah i could do that, but then i would be missing out on a repair job.
Old Feb 14, 2007 | 07:56 PM
blackmfoggie's Avatar
I have a 92' accord and the check engine light is on. my car shuts off at any time after its warmed up or when i put it in neutral, thats only when the light is off. When the light is on the car runs perfect but just sluggish, lack of power, but burn gas faster. i checked my egr valve and there is no vacuum. I don't know if its the egr solenoid or the actual egr valve. Any suggestions on what it might be?
Old Feb 14, 2007 | 07:58 PM
Old Feb 15, 2007 | 02:12 PM
hondadude's Avatar
Default Re: EGR valve has vacuum at idle??? (blackmfoggie)
Check the code; here's how
http://members.troublecodes.ne...n.jpg
Old Feb 15, 2007 | 04:35 PM
i took my car to the shop and they said that its somethin about an secondary air injection switch vavle. i don't know what it is and i tried researchin it online but nothin came up. and they also said somethin bout a cold start.
Old Feb 15, 2007 | 07:18 PM
hondadude's Avatar
I'm going to have to guess that you have the EX model? or should I keep guessing?
Old Feb 16, 2007 | 04:51 AM
yup, i have the ex model which is a litte bit different from other models.
wrichey1
Apr 28, 2013 04:54 AM
78F350
Jul 27, 2012 11:03 AM
JBirch_97Prelude
Mar 26, 2007 08:43 AM
k20rex
Jul 21, 2006 02:19 AM
caliquick_teg
Jan 23, 2003 05:34 AM
