help with my auto tranny
Old Dec 12, 2006 | 09:37 PM
carbonek9's Avatar
Default help with my auto tranny
ok i need help with my auto tranny its starting to go and it slips every time i take a turn it just revs up i was told from the tech that last worked on my engine that my clutches on my auto tranny were really low. any why can someone help me with step by step on how to take out a tranny on a 2000 honda civic 4 dr dx it has a stock d16y7 engine. so if u can help thanks
Old Dec 13, 2006 | 07:37 AM
ryc555's Avatar
if you do all have the proper tools you can DIY!
Old Dec 13, 2006 | 09:20 AM
teal_dx's Avatar
Default Re: (ryc555)
buy a helms manual, everything you'll need to know. It's possible to do it w/o removing the motor, but easier to work with if you just drop the motor from the bottom.
Old Dec 13, 2006 | 09:50 AM
Syndacate's Avatar
Default Re: (teal_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx &raquo;</TD></TR><TR><TD CLASS="quote">buy a helms manual, everything you'll need to know. It's possible to do it w/o removing the motor, but easier to work with if you just drop the motor from the bottom. </TD></TR></TABLE>
Word.
Easiest way I've seen is to jack up the front, take the fender off (for clearance), then put a jack on a piece of wood and let the whole engine down. If you let just the tranny side down, sometimes it puts too much stress on the driver's side mount. You don't need to get it out, just lower it, so you can just lower it on a jack (sorta like putting the engine on a stand) and then can remove the tranny - then just pump it back up into there when you're done.
I don't know, easiest way I've seen asside from a trick my friend used once which was unbolt the mounts, put a front end loader with forks instead of a bucket up to the side put the forks right through the windows, lift the car 20 ft in the air and the engine just sits there...
This only works if you have a front end loader with a fork end (instead of a bucket)...
It was also a totalled car....and I don't know how much damage ur gonna do to your car by doing it that way. Not recommended unless the body's junk, but takes 10 ******* minutes after you let all the freon out....
Joshyboy2929
May 20, 2018 06:17 PM
gabb1
Jul 13, 2009 02:33 PM
d5civic
Honda Civic (2001 - 2005)
Apr 2, 2008 09:48 PM
rleonekc
Apr 17, 2006 03:22 AM
BigBank420
Feb 17, 2004 01:48 PM
