obd1 conversion
Old May 11, 2002 | 03:44 PM
bbb18c1's Avatar
Default obd1 conversion
Has anyone done a obd1 conversion on a 2000 gsr (obd2 ver.2)
I tried, but the car will not idle. the obd1 ecu is fine and the harness is also good.
but the car dies after 2 second when i start it. The a/f gauge reade lean and then dies.
any help would be appreciated.
-thanks
Old May 11, 2002 | 06:52 PM
Trigun's Avatar
Default Re: obd1 conversion (bbb18c1)
i did ... i have a 2000 gsr also and i'm running an obd1 hondata prepped ecu and it works great.
when i first got the obd1 ecu, i plugged it in with a skunk2 harness and drove around and everything was fine .. no hesitation. the car never died while idling but the rpm's did drop a little lower than normal during intial startup but then the car just settled down into normal idle range (not lower than 750rpm).
Old May 11, 2002 | 07:33 PM
jteasy's Avatar
New User
Default Re: obd1 conversion (Trigun)
I have the OBD1 and I had to loosen the idle screw on the throttle body all the way out, my car revs up and down when I come to a stop from around 800 rpms to 1400 rpms. You have to get the OBD1 series throttle body to match the ecu, this is because on the OBD1 cars the TB has an extra valve on the TB that controls the idle, and on the OBD2 cars, the TB does not have it. I have only been told this by JOTECH motorsports and have not had the the money to do this swap myself, but it is on my list.
Old May 11, 2002 | 10:43 PM
LillDragun's Avatar
Default Re: obd1 conversion (JTEASY)
is it possible to be done on a 2001 LS?? how much would the whole conversion come out to??
Old May 12, 2002 | 12:25 AM
bbb18c1's Avatar
trigun and jteasy
thank for the info.
I didn't know that i would have to swap out the throtttle body to get the obd1 ecu to work properly. I guess i'll have to do that to try and fix the problem.
I also read some posts that i have to get a obd1 distributor to get it to work properly.
do you know how much a throttle body from a obd1 gsr would cost?
Old May 12, 2002 | 01:26 AM
PaChiLa Leader's Avatar
I have the same problem here with my OBD1 conversion but in my case
I have a 2001 GS converted to Stick with 99 GSR tranny then Skunk2 Harness + 95 OBD LS 5 speed ECU.
Came cross with 3 problems:
1. RPM Needle doesn't funtion..... (Mechanic found out that was a wire missing or some sort... so he adds an extra line from coil to the ecu to make it work)
2. Car doesn't idle right when i start it....... running lean, Stalling and then shut down.... Any Ideas?
3. Cruise control doens't work..... I don't have Clutch Switch on mine
so the car starts without ingage the Clutch
Anyone??
Please help?
Car idles suck and what happened to me today was the car shut down during rush hour traffic then it won't start till i tried 2 mins.....
ANY helps would be helpful~~
please help
[Modified by PaChiLa Leader, 2:46 AM 5/12/2002]
Old May 12, 2002 | 02:40 AM
b18c1civic95's Avatar
Default Re: obd1 conversion (b18c1)
I have a 1998 Gs-R in my hatch wired to a 1995 Gs-r Ecu i had the problem with the idling kinda surging up then dropping off like a small rev but i took it back to the guy and he just plugged up one of the vaccum lines thaT i no longer needed and it runs great now..... i did not have to replace the throttle body or anything.... it costed me 400 dollars to get it wired up...... i was told that i wouldnt have a fast idle because of the difference but everything works fine like i said..... but maybe something is different to the 00?? no shops u can ask??
Old May 12, 2002 | 05:21 AM
98gsRAW's Avatar
Default Re: obd1 conversion (b18c1civic95)
Same story here in my 98, just used a old vacum line on mine too! runs like a champ now
-98gs-raw
Old May 12, 2002 | 12:43 PM
Default Re: obd1 conversion (98gsRAW)
Can you guys tell me more about the Vacuum line?
coz i have to do it myself at home yo......
besides i don't even know what Vacuum line looks like...
I am really new to teg's ECU wirings
please please help me out here....
Provide me some pics if you can
THank you so much
[Modified by PaChiLa Leader, 1:47 PM 5/12/2002]
Old May 12, 2002 | 01:15 PM
Sintegra's Avatar
Default what about the obd1 makes it better than obd2's?
Im pretty sure i have obd1 in my 94 LS, what's so great about it? Y do people convert?
Old May 12, 2002 | 01:31 PM
Default Re: what about the obd1 makes it better than obd2's? (Sintegra)
you can run test pipe without CEL light came up~~
Old May 12, 2002 | 02:16 PM
neo1z's Avatar
Default Re: what about the obd1 makes it better than obd2's? (PaChiLa Leader)
actually just get a test pipe with o2 bungs and you can do it just fine with no cel...
Old May 12, 2002 | 06:27 PM
bbb18c1's Avatar
Default Re: obd1 conversion (PaChiLa Leader)
b18c1civic95
and
98gsRAW
do you guys know which vaccum line i have to plug to get it to run.
I have to do this myself also because the local shops tell me that it should run as soon as i plu in the ecu.....they have no idea what is wrong.
thanks
Old May 12, 2002 | 11:09 PM
yeah theres no body and shops around here knows what i am talking about...
i have to do it myself at home i guess.....
so please help
Old May 13, 2002 | 01:50 PM
bbb18c1's Avatar
nobody knows?
Old May 13, 2002 | 07:45 PM
up
someone must know this~~
please help
Old May 15, 2002 | 12:10 AM
Old Jul 26, 2002 | 12:23 AM
RC211V's Avatar
i thought all you needed was the s2 harness and a p72 ecu. an i wrong? what is causing all these problems?
Old Dec 29, 2002 | 03:48 AM
Default Re: obd1 conversion (JDMintegGSR)
up
Old Jan 12, 2003 | 01:37 PM
BuddhaSiR's Avatar
Default Re: what about the obd1 makes it better than obd2's? (neo1z)
Wrong, CEL will still come on.
Old Jan 12, 2003 | 01:40 PM
Default Re: what about the obd1 makes it better than obd2's? (BuddhaSiR)
Nah~ with OBD1 and test pipe.. on my 2000 GS .. the CEL light doesn't come on~~
don't even want to bother argue with you on the net.. but it works for me.. so whatever
[Modified by PaChiLa Leader, 5:41 PM 1/12/2003]
sevenfc
Apr 22, 2009 08:02 PM
vtec-adykt
Apr 14, 2007 10:42 PM
JDM96SpecCTR
Nov 14, 2004 04:36 PM
allmotortypegsr
May 26, 2003 01:04 PM
