gsr rebuild itr internals
Old Dec 12, 2006 | 06:47 PM
Pnoyej6's Avatar
* B A N N E D *
Default gsr rebuild itr internals
I have 96 cx civic hb with usdm gsr 97 swap. Car is at shop. What compression should i be at guys with
Itr Pistons
Itr cams
Brand new oem hg,
New oem rod bearings
Honed block
Itr cams
Gsr valvetrain
Head machined inspected by machine shop
Valve 3 angle job all seals replaced valve
Blox im
WIll be getting my car dynotuned after rebuilt with obd 1 chipped p72. Should i yield 11 5 1 compression. Is this good for running 91 octane? How much whp youthink i should pull guys??
Old Dec 12, 2006 | 06:50 PM
poison's Avatar
Default Re: gsr rebuild itr internals (PnoyEj6)
You should be fine with 91 octane with 11.5 CR.
WHP depends on a lot of things. Type of dyno, humidity, temperature, fuel maps, and most of all, the Tuner.
Old Dec 12, 2006 | 07:00 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: gsr rebuild itr internals (poison)
SO a gsr with itr internals should yield approximately 11 5 compression?
Old Dec 12, 2006 | 07:08 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnoyEj6 &raquo;</TD></TR><TR><TD CLASS="quote">SO a gsr with itr internals should yield approximately 11 5 compression?</TD></TR></TABLE>
And god looked down upon his pple and said "let their be compression calculators..."
Old Dec 12, 2006 | 07:11 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: gsr rebuild itr internals (Syndacate)
i check the website and approximately 11 4
Old Dec 12, 2006 | 07:16 PM
Itzmy91Teg's Avatar
depends on what the shop takes off when they resurface
NemesisCBR
Sep 15, 2011 06:03 AM
candy eg
Apr 22, 2006 04:56 PM
playalistic2
14
Dec 7, 2005 01:07 PM
93dx--hatch
Oct 8, 2003 06:04 PM
lazyvietboi
Nov 5, 2001 07:44 PM
