fuel pressure gauge install?
Old Dec 12, 2006 | 06:34 PM
killerpenguin21's Avatar
Default fuel pressure gauge install?
anyone have instructions? id like to know how to do it before i go ahead buying one. is it better to run one on the filter or on the rail?
basically any info would be greatly appreciated.
Old Dec 12, 2006 | 06:47 PM
poison's Avatar
Default Re: fuel pressure gauge install? (killerpenguin21)
Doesn't really matter where you run it. A lot of people install it on the fuel filter. It's just a matter of putting fittings on the rail/fuel filter and "T"ing it with the fuel lines.
Old Dec 12, 2006 | 08:16 PM
Syndacate's Avatar
Default Re: fuel pressure gauge install? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't really matter where you run it. A lot of people install it on the fuel filter. It's just a matter of putting fittings on the rail/fuel filter and "T"ing it with the fuel lines.</TD></TR></TABLE>
Yup, just T it off where it plugs into the fuel rail.
Old Dec 12, 2006 | 09:27 PM
Default Re: fuel pressure gauge install? (Syndacate)
are the fittings included with the gauge on camp1320 the only ones needed?
Old Dec 12, 2006 | 11:23 PM
F20Cteg's Avatar
Yes he sells them with the new banjo bolt, new copper washers, and the 90 degree fitting.
1) Take off the old banjo bolt.
2) Install the new banjo bolt with new washers.
3) Put teflon on the 90 degree fitting.
4) Screw 90 degree fitting into banjo bolt. Tighten so that it faces forward.
5) Put teflon on the gauge threads.
6) Screw gauge into 90 degree fitting.
Old Dec 13, 2006 | 07:07 AM
Default Re: fuel pressure gauge install? (F20Cteg)
thanks man!
Old Feb 14, 2007 | 01:46 PM
1badteg's Avatar
This thread is old but for those still interested here is a link to the install.
http://www.c-speedracing.com/h...e.php
Old Sep 14, 2008 | 10:14 AM
beyb1976's Avatar
did you get a gauge and what are you running for pressure i just did a turbo kit and need to adjust
eastbobdam
Sep 13, 2008 04:17 PM
SiYouLater
Apr 14, 2007 11:42 AM
TMC_EF
Mar 22, 2007 01:07 PM
B16CRXT
Apr 2, 2005 10:19 AM
ComputerJLT
Feb 26, 2004 08:32 PM
