Problem With Car
Old Dec 12, 2006 | 02:46 PM
Gutted Si's Avatar
Default Problem With Car
OK the car has been overheating a bit, and leaking Rad Fluid. At first I thought it was just the cap So i bought a new one and everything was fine. Took it into a little boost and the car went from sounding like a honda and no white smoke, to sounding like a subarau and filled the inside of my car with smoke. Pulled over right away, and turned it off. MY rad was leaking from the bottom. Fixxed the leak, Flushed the system. Let the car idle for about 5min and everytthing was fine. Went to drive the car again. No overheating, just shifted into 3rd at about 17vac 2.2k and when i hit 4th went back to a subby sound and filled my car with smoke again. Turned car off and it sits on the side of the road as I type this. Yes all house, clips and everything is plugged in and the car was filled with all fluids. There was no Rad fluid in the oil, took the plugs out they were are fine.
Rfisherxo
Jan 14, 2012 06:35 AM
OneFire
Jun 22, 2010 02:50 PM
eroxer310
Jul 3, 2008 06:01 PM
blackgrrl23
Aug 28, 2003 12:11 PM
