Do any of you drive without factory O2 sensor??
Old Dec 12, 2006 | 02:24 PM
vtec.dc2's Avatar
Default Do any of you drive without factory O2 sensor??
If you do, do you still manage good mpg?? Lets say if you installed wideband with hondata, do you need to retain factory O2 sensor? Can someone explain on how that works?
Old Dec 12, 2006 | 02:44 PM
cueballsi's Avatar
Default Re: Do any of you drive without factory O2 sensor?? (vtec.dc2)
i drive withthe wideband in and it emulating a narrow band into my ecu
Old Dec 12, 2006 | 02:45 PM
igo4bmx's Avatar
depends if you run closed loop/open loop
Old Dec 12, 2006 | 02:48 PM
vtec.dc2's Avatar
Default Re: Do any of you drive without factory O2 sensor?? (cueballsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cueballsi &raquo;</TD></TR><TR><TD CLASS="quote">i drive withthe wideband in and it emulating a narrow band into my ecu </TD></TR></TABLE>
does it emulate narrowband signal through wideband controller? what type of wideband do you use?
Old Dec 12, 2006 | 02:58 PM
Timmay's Avatar
ive disabled all my o2's in my personal cars .. tuned on crome
Old Dec 12, 2006 | 03:47 PM
cueballsi's Avatar
I run a zetronix WBO2
Old Dec 12, 2006 | 03:58 PM
borat's Avatar
I keep my Innovate LC-1 in place of the primary factory sensor, open-loop mode on crome. Getting 19 mpg in the city with lots of boosting.
Old Dec 12, 2006 | 04:54 PM
turbosi03's Avatar
Default Re: Do any of you drive without factory O2 sensor?? (borat)
I use just the PLX 250 wideband, no stock sensor with Hondata open loop.
Basically you can either run closed loop which uses o2 sensor info to adjust A/F mixture within some tolerance, OR run open loop where the ECU rely's on your fuel maps set by you or your tuner to get the right A/F mixture.
DC2R96
Feb 11, 2011 02:17 PM
jeffy
Mar 21, 2008 02:36 PM
TheHatchHog
Oct 12, 2004 07:18 AM
89turboteg
Feb 11, 2002 07:19 PM
