No spark??? got fuel and air..
Old Dec 12, 2006 | 08:47 AM
flip1199's Avatar
Default No spark??? got fuel and air..
it's a stock 95 civic ex. checked for spark and had none so i replaced the dizzy with a reman from napa autoparts. the dizzy came with new ignitor and coil. i swap it in and it still has no spark. what else could it be?? i know the alternator is a little weak but while trying to start the car i had the battery jumped with a known good one just to make sure there's enough power. but still no spark?
Old Dec 12, 2006 | 11:45 AM
tietze's Avatar
Default Re: No spark??? got fuel and air.. (flip1199)
Check all the fuses, especialy #36
There should be 12v at the BLK/YEL wire going to the coil and igniter with the ignition key in the "on" position, if not follow back thru ignition switch, f39,f41.
You can check the coil with an ohmmeter..
disconnect wires to coil, should be....
.6 to .8 ohm from A to B
13,200 to 19,800 ohm from A to secondary winding, (spark plug output)
Igniter input check..
disconnect all 4 wires from igniter, be sure none are touching chassis ground, then turn on ignition switch.
There should be battery voltage between BLK/YEL and ground, if not, ignition switch, f39, f41.
There should be batt volts between BLU/WHT and gnd, if not ,coil.
Old Dec 12, 2006 | 12:23 PM
instructor74's Avatar
Default Re: No spark??? got fuel and air.. (tietze)
wow tietze did you know that of the top of your head or did you cheat like I was and look it up in the manual .......you beet me to the post lol
Old Dec 12, 2006 | 12:24 PM
tietze's Avatar
Default Re: No spark??? got fuel and air.. (instructor74)
cheated, got the manual on pdf
I wish I knew how to do a cut n past from a pdf to a reply. It would make it easier.
Kyogie12
Dec 14, 2011 04:30 PM
thereverendstu
Jan 25, 2010 08:16 PM
zortmo
Jul 29, 2006 06:32 PM
B18ceed
Mar 18, 2006 04:41 PM
rizzoTK
Aug 29, 2005 02:35 PM
