clutch compression question
Old Dec 11, 2006 | 08:12 PM
j00n325's Avatar
Default clutch compression question
Hey,
Got a question for you all. I recently got a new clutch on my car. It's a 99 ek hatchback. The new clutch is nothing special. When I got the car back, the clutch was very easily depressible. It felt exactly like my cousins rsx type s clutch. There was very little resistance, and felt very light. Now here's the problem. I took it to one of my friends shops to get it checked out, and the guy changed the way the pedal felt when it's pressed, making it feel a lot like how it was before the clutch installation. He didn't do anything major, but he did tighten something up. So basically I want the clutch pedal to feel like it did after I got the new clutch installed. Any insight on how I could go about doing that?
Old Dec 11, 2006 | 08:48 PM
MidwestSiR's Avatar
put yourself upside down by the pedals..
you'll see the adjuster nut for the pedal..
adjust the pedal to where you want it
Old Dec 11, 2006 | 08:51 PM
MidwestSiR's Avatar
Default Re: (MidwestSiR)
obviously the pedal to the far left is the clutch pedal...
Part #15 is the adjustment
https://www.hondaautomotivepar...5.gif
Old Dec 14, 2006 | 09:10 PM
j00n325's Avatar
hmm thank you for the help. i'll check it out once i get some free time.
Old Dec 14, 2006 | 09:46 PM
j00n325's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestSiR &raquo;</TD></TR><TR><TD CLASS="quote">put yourself upside down by the pedals..
adjust the pedal to where you want it</TD></TR></TABLE>
Ok, so went under there, took a look around and saw what looked to me like part #15. it looked like a small rod, with a bolt holding it in place. the rod had a wire connected to the far end. is this the piece i'm supposed to be adjusting? or am i actually looking at part #40?
Old Dec 14, 2006 | 10:31 PM
j00n325's Avatar
ok, man, i went back out there. i am definately looking at part #15. I'm not exactly sure what to do though. this piece has a pin looking thing sticking out from the end of it, and when the pedal is pressed in all the way, it presses this pin in.
ok, i just want to make sure we're on the same page. what i'm trying to do, is make it so that the pedal can be pressed more easily. from the moment i touch it, to when my foot hits the floor. basically i'm trying to get less resistance from the pedal.
will adjusting part #15 achieve that? it seems like all i would be doing is changing how deep the pin gets pushed in by the pedal instead of changing the amount of resistance the pedal is pushing back on my foot.
Old Dec 16, 2006 | 11:14 PM
j00n325's Avatar
Default Re: clutch compression question (j00n325)
bump
jrap1243
11
Jan 9, 2008 09:18 PM
Built B18ABorC
Aug 28, 2004 02:02 PM
Steve
Jul 23, 2001 01:42 PM
