DA engine/trans swap
Old Dec 11, 2006 | 07:53 PM
panovel's Avatar
Default DA engine/trans swap
i have a 90da w/ auto trans and blown engine. im buying a 91da w/ manual trans and good b18a it has severe body damage. anyhow on the swap any special things i need to switch over such as harnesses,computer etc. besides the basic engine, trans, shifter, clutch/brake pedals. also is the hole in the body for the shifter or do i have to cut one? any and all info greatly appreciated. this seems like a lot of work for such an older teg but i just couldnet stand to see them both crushed so i figured i make one good one
Old Dec 12, 2006 | 07:36 PM
g2daturbo's Avatar
Default Re: DA engine/trans swap (panovel)
trans , flex plate instead of flywheel linkage instead of cable, half shaft is different chance out the ecu and passanger side engine mount is different
Old Dec 12, 2006 | 08:49 PM
Elbowpunk's Avatar
hey bro i crashed my 91 integra (auto) and got a 90 integra with a manual tranny in it.... so i took jsut the motor out and swapped it in the 90.. everything is the same... Obd0 and everything mounts up the same... nothgin different expect the clutch set-up, the pedals, cables and flywheel...and u need a new driver side inter shaft for the axle... new motor mounts a plus ! and some patences
phirewire
Aug 11, 2024 03:41 PM
EaglesfanUT
Honda Civic (2001 - 2005)
Jan 9, 2016 08:13 AM
Hoopdie91
Apr 16, 2015 09:13 PM
JDMjdw
Apr 12, 2006 06:15 PM
rrh22
Oct 28, 2004 06:01 AM
