Fan install
My 96 accord ex f22 just got out of the shop. One of the things they told me was that my secondary fan was not working and needs to be replaced. First question- which one is the secondary (driver side, or passenger side), and two- does anyone know of any write-ups on this where people have just dropped in slim fans? I know a slim fan would probably be cheaper than the oem one. I dont know exactly what it would wire in to. Any help would be appreciated, even if it's just a link.
Thanks guys.
Thanks guys.
You can OPEN THE HOOD and turn on the A/C to be sure of which fan is not working. Secondary usually means the condensor fan on the drivers side. Then you'll see that there are a couple 10mm bolts at the top of the fan and one at the bottom, and it lifts right out so you can take it to a bench and replace the fan motor. Yeah those fan motors are pretty costly around $150.
Thanks for the answer, I was also wondering if anyone had already/knew how you install (the wiring portion) on one of these aftermarket slim fans, seeing as an OEM replacement is looking pretty pricey.
jonesEK
16
Mar 6, 2012 03:49 PM
Rah Rah
Jun 3, 2004 06:08 AM
