headgasket/cam gear setting?
Old Dec 11, 2006 | 06:27 PM
aznej2's Avatar
Default headgasket/cam gear setting?
Ok i have been searching for over an hour now and cant really find anything on it. I have read a post before that stated this stuff but cant seem to find it now. Anyways i am planning to use a single layer (middle layer) headgasket on my motor and forgot how much i need to advance/retard the camshafts to "zero" them the head and block have not been milled.
Old Dec 11, 2006 | 06:28 PM
aznej2's Avatar
Default Re: headgasket/cam gear setting? (aznej2)
Thanks for any help in advance
Old Dec 11, 2006 | 06:32 PM
Runnerdown's Avatar
milling the head and running a thinner headgasket RETARDS the cam timing. I hope you have checked clearances like piston to valve and quench. Thats a lot to take off without checking
Old Dec 11, 2006 | 06:49 PM
aznej2's Avatar
Default Re: headgasket/cam gear setting? (Runnerdown)
i did not mill my head only using the single layer HG how much do u retard for taking off 2 layers? (two outside layers)
Old Dec 11, 2006 | 07:00 PM
Runnerdown's Avatar
I know you didnt mill the head but its the same principle. I'm not sure exactly how much to turn the gears to compensate. What kind of cams are they. probably shouldnt be on zero anyway but thats another story.
Old Dec 11, 2006 | 07:04 PM
91SiZ6's Avatar
The cam will be retarded 1.2 degrees for every .01" taken off/out.
Old Dec 11, 2006 | 07:11 PM
aznej2's Avatar
Default Re: (91SiZ6)
im runnin toda c's i know they should b on zero... but im just tryin to figure out the zero for self knowledge i guess... anyone happen to know the thickness of each of the layers? thanks
Old Dec 12, 2006 | 03:02 AM
Runnerdown's Avatar
Default Re: (aznej2)
they need to be degreed, zero is an irrelevent number. if not that, then put it on a dyno and see what works.
thekooler
27
Mar 23, 2012 05:25 AM
#Leo#
Mar 22, 2010 09:54 AM
psegs80
Mar 4, 2006 10:59 AM
Power Rev Racing
Jul 1, 2005 09:50 AM
sik_sol
Apr 2, 2005 12:52 PM
