QUICK REDLINE @ 3,000 RPM????????????????????????????????????????
I WAS WONDERING WHY MY CAR AFTER DRIVING FOR A WHILE, AND IT HEATS UP LIKE NORMAL 1/2 WAY, THE CAR BOGS DOWN AND THEN IF YOU GIVE IT GAS , IT WOULD ONLY GO UP TO 3,000 RPM, LIKE IF IT WAS TO HAVE 2-STEP OR SOMETHING???????????????????
caps off plz...and it sounds like ur running on three cylinders. chech ur plug and plug wires like he said ^
check your plugs and wires first, but if thats not it i had a buddy with the same prob. turned out he had a bad ecu.
but if i put a po6 ecu it goes away, but i dont think my ecu is bad because it was running perfectly fine, and it is also chipped so it was running fine when it was done, now it is acting retarded
you fried your chip. mine only revs to 4000 after i erased my chip. either that or check the chip to make sure that it is securely in place, sometimes they can get knocked loose and it will run funny
It probably won't set a code. Hondas are known to have huge problems with there spark systems. Check the coil, cap and rotor, wires, and plugs before going into any thing else.
mind did this like 3 months ago..... it was my distro. cap was cracked. get a new distro cap and router button .. might as well new plugs and wires too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ejalldaipesos »</TD></TR><TR><TD CLASS="quote">but if i put a po6 ecu it goes away, but i dont think my ecu is bad because it was running perfectly fine, and it is also chipped so it was running fine when it was done, now it is acting retarded</TD></TR></TABLE>
Dude, did you just say a different ecu makes it run right? Umm, if thats the case, I'm going to go ahead and make a bold move here: its your ecu. Yes, it may have worked before, most items that go bad did in fact work at one point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyal 951 »</TD></TR><TR><TD CLASS="quote">
Dude, did you just say a different ecu makes it run right? Umm, if thats the case, I'm going to go ahead and make a bold move here: its your ecu. Yes, it may have worked before, most items that go bad did in fact work at one point. </TD></TR></TABLE>
Yeah, ****, even those ebay turbo kits work at one point
See if you can use chrome or something and reload the .bin file of the P06 ECU. If not...then maybe it's time for another one.
.See if you can use chrome or something and reload the .bin file of the P06 ECU. If not...then maybe it's time for another one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">sounds like you may have a bad ecu.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">check if its throwing any new codes.
i dont understand why this wouldnt be the first step you took?</TD></TR></TABLE>
exactly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMEK-9 »</TD></TR><TR><TD CLASS="quote">sounds like u need to TAKE THE CAPS KEY OFF!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1FORLIFE. »</TD></TR><TR><TD CLASS="quote">caps off.</TD></TR></TABLE>
great input
exactly
great input
apexiintegra
Apr 7, 2003 10:34 AM
