oil in spark plug chamber questions
Old Dec 11, 2006 | 06:18 PM
chrimy90cx's Avatar
Default oil in spark plug chamber questions
hey guys/Gals
I have always gotten great answers on Honda-Tech and i bet i will agian i change my plugs on my d15b2 and cylinder 1 3 and 4 were all ok my question is this cylinder 2 had oil in it when i pulled the plug out i burn a bit of oil when i am a little hard on the gas is this the problem is it just a seal. Anyone ever have this problem do i need to replace my motor. Thank you for all you help in advance.
Chris
Old Dec 11, 2006 | 06:24 PM
Zaakro's Avatar
Default Re: oil in spark plug chamber questions (chrimy90cx)
just replace the tower seal under the Valve cover
Old Dec 11, 2006 | 06:27 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: oil in spark plug chamber questions (Zaakro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">just replace the tower seal under the Valve cover</TD></TR></TABLE>
X2 agreed
Old Dec 11, 2006 | 06:28 PM
wiZCo's Avatar
Stouts 'n' Scotch
x3
Old Dec 11, 2006 | 06:31 PM
chrimy90cx's Avatar
Wow that was fast does anyone hav a link to do this will this be in my helms as tower seal. I am gonna seach it thank you for your help
Old Dec 11, 2006 | 07:14 PM
chrimy90cx's Avatar
Hey i have searched and foudn nothing i also look in my haynes and cant locate any inof can anyone help?
Old Dec 11, 2006 | 07:20 PM
civicflow's Avatar
spark plug tube seal could be it hopefuly. could even be valve stem seal but try the spark plug tube seal
Old Dec 11, 2006 | 07:26 PM
chrimy90cx's Avatar
thanx again
anyone done this hwo difficult is it i guess a new vavle cover is also required
is it safe to drive my car still.
thanks
Old Dec 11, 2006 | 07:30 PM
sierrakilo's Avatar
I've probably put 50k miles on mine since I noticed the oil in the spark plug chamber last year. I'm using about a quart every 3-5k miles. Engine has 200k+ miles on it, still getting 35mpg though...
Old Dec 11, 2006 | 07:41 PM
Steri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrimy90cx &raquo;</TD></TR><TR><TD CLASS="quote">thanx again
thanks
You don't need a new valve cover, you could get a new valve cover gasket but all you need to do is replace the tube seals. Just take off the valve cover and pull out the old ones and push in the new ones it'll take 10 mins.
Old Dec 11, 2006 | 07:46 PM
fireant's Avatar
Default Re: oil in spark plug chamber questions (89EF_Sleeper Si)
This might help... its for a D16A6 (Si) but its nearly the same procedure:
http://www.hondaworkshop.com/c...skets/
Old Dec 11, 2006 | 07:49 PM
chrimy90cx's Avatar
Default Re: oil in spark plug chamber questions (fireant)
THank you HONDA-TECH!!!! i owe u guys!!! i will do this this weekend. I asked a question about my pcv valve on saturday and got a reply just as fast worked out great thank you again
Old Dec 11, 2006 | 08:16 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrimy90cx &raquo;</TD></TR><TR><TD CLASS="quote">THank you HONDA-TECH!!!! i owe u guys!!! i will do this this weekend. I asked a question about my pcv valve on saturday and got a reply just as fast worked out great thank you again</TD></TR></TABLE>
H-T pulls through occasionally...
Without H-T my car would be non-existant.
Old Dec 12, 2006 | 04:17 PM
Hondasmo's Avatar
After you replace your valve cover gasket and your 4 spark plug tube seals if you still are gettin oil in cylinder #2 spark plug tube then id recommend you have your pedistal o-rings replaced oil may be leaking in the tubes thru the valve trane .. oil in spark plug tubes = ruined spark plug wires ... also will cause carbon tracking of the spark plugs = Misfire
Old Dec 23, 2006 | 01:14 AM
hybridclassic626's Avatar
Default Re: oil in spark plug chamber questions (Hondasmo)
bump cause i'm not trippin no more lol
Old Dec 23, 2006 | 08:48 AM
janz3n's Avatar
Default Re: oil in spark plug chamber questions (hybridclassic626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondasmo &raquo;</TD></TR><TR><TD CLASS="quote">After you replace your valve cover gasket and your 4 spark plug tube seals if you still are gettin oil in cylinder #2 spark plug tube then id recommend you have your pedistal o-rings replaced oil may be leaking in the tubes thru the valve trane .. oil in spark plug tubes = ruined spark plug wires ... also will cause carbon tracking of the spark plugs = Misfire </TD></TR></TABLE>
if your talking about the O rings at the bottom of the spark plug tube then im with ya on that one.. iv had two engines leak from there.. you can usually see oil leaking on the top if its the seals up there. but those are easy to fix.. you shouldnt need a manual to replace that. just take the valve cover off and replace teh gaskets.
usdmEHboy
Jul 23, 2007 09:08 AM
lude98SH
Aug 23, 2006 06:48 PM
BI8B
21
Jan 30, 2005 12:58 PM
EIT_certified
Aug 1, 2004 08:33 PM
typeeg
Jun 9, 2004 02:33 PM
