Time for an engine rebuild - what seals should i get
Old Dec 11, 2006 | 04:40 PM
drumminforev's Avatar
Default Time for an engine rebuild - what seals should i get
Puttin new piston rings. wondering what specific seals i should get to go along with it. Only the neccesary ones.
And what about main bearings. I been driving with blowby for a year so gas was often in the crank...
b16a2
Old Dec 11, 2006 | 08:45 PM
Muckman's Avatar
Moderator in Chief
Default Re: Time for an engine rebuild - what seals should i get (drumminforev)
OEM for everything if possible. OEM is recommended for stock pistons. Or if your running aftermarket pistons, then use their recommended rings.
Old Dec 11, 2006 | 09:47 PM
91SiZ6's Avatar
http://www.HondaAutomotiveParts.com
http://www.SLHonda.com
Old Dec 14, 2006 | 11:09 AM
Default Re: (91SiZ6)
Ok well i was asking WHAT do i need to replace. i really need your help. i dont have long left to do my rebuild
Old Dec 14, 2006 | 11:30 AM
Muckman's Avatar
Moderator in Chief
Default Re: (drumminforev)
Get an OEM Top end AND Bottom end gasket set from Honda. Order the same bearing codes based upon the markings on the crank, rods, block (see your service manual for clarification).
Old Dec 16, 2006 | 08:15 PM
Default Re: (Muckman)
All i need is the bare essentials meaning i just want to do rings and anything that i absolutely have to
please list the parts specifically.
Old Dec 17, 2006 | 07:26 AM
Muckman's Avatar
Moderator in Chief
Do you want me to order and install them too?
Old Dec 17, 2006 | 02:05 PM
91SiZ6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev &raquo;</TD></TR><TR><TD CLASS="quote">All i need is the bare essentials meaning i just want to do rings and anything that i absolutely have to
please list the parts specifically.</TD></TR></TABLE>
Your repair manual will tell you what the bare essentials are. Anything past that is on you. A basic rule of thumb is, if you take it apart replace the gasket/seal...read your repair manual to find exceptions.
Old Dec 17, 2006 | 02:39 PM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Do you want me to order and install them too?</TD></TR></TABLE>
Hahaha
Yea, take a little initiative on your own car.
Old Dec 18, 2006 | 10:44 PM
Default Re: (attentionwhore)
Yeah bein a dick helps.
I just need to know if i need something like a main seal or something, along with the oil pan gasket and not sure what else is necessary
Old Dec 19, 2006 | 01:45 AM
91SiZ6's Avatar
Ok, slow down for a second and think about this. Do you think it'd be a good idea to replace the rear and main seal while you have the engine apart just to be on the safe side? The diagrams in a repair manual will tell you what gaskets/seals need to be replaced. This is the common sense part, man.
redsolturbo
May 27, 2009 09:51 AM
ITR.#1446
Jul 22, 2008 09:34 PM
DarKStaR5
Jan 29, 2007 07:19 PM
bb4socal
Nov 14, 2006 09:07 PM
ThatsMyEG
Dec 23, 2004 12:49 PM
