91 accord
i have a problem with me car geting stuck in 2th gear it will run fine then the car will just drop to 2th help
Modified by blas0827 at 4:47 PM 12/13/2006
Does your D4 light (on the dash) come on, when it's not supposed to be on (when the car is in Park). If so, you may have a transmission computer problem. You can open the computer to check it out (dark spots on curcuit boards from leaky capacitors).
If the D4 light is flashing when you turn the key on, you have a transmission code stored.
Guest
Posts: n/a
sound s like you might have a tanny computer problem... this might help
http://techauto.te.funpic.org/transmission.php
xid002
Jun 5, 2008 05:13 PM
