picking up ls block need to know!!!
Old Dec 11, 2006 | 03:59 PM
JLefevers's Avatar
Default picking up ls block need to know!!!
ok i am prolly goona go look at a bare ls block and the ls crank i know to look for cracks on the block and pits in the cylinder walls anything else sombody could throw out there for me to look fopr also how can i tell if the crank isworth getting?? any info will help
Old Dec 11, 2006 | 04:06 PM
mahatma's Avatar
Default Re: picking up ls block need to know!!! (JLefevers)
look for weird discoloration around the bearing journals.....purple is bad. any scarring or evidence of a spun bearing and i'd stay away, seriously
Old Dec 11, 2006 | 04:15 PM
dr_latino999's Avatar
Default Re: picking up ls block need to know!!! (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">look for weird discoloration around the bearing journals.....purple is bad. any scarring or evidence of a spun bearing and i'd stay away, seriously</TD></TR></TABLE>Visually check as many of the bolt holes as possible to see if the threads are fubared.
Old Dec 11, 2006 | 04:17 PM
Tippyman's Avatar
Default Re: picking up ls block need to know!!! (dr_latino999)
Both good sugestions. Check those cylinder walls with a really bright light from different angles. Sometimes you can't see a problem without getting a shadow on it...
Old Dec 11, 2006 | 04:32 PM
JLefevers's Avatar
Default Re: picking up ls block need to know!!! (Tippyman)
cool all suggestions will be used any others?
Old Dec 11, 2006 | 07:54 PM
AndrePerras's Avatar
look for burn marks on the crankshaft, and grooves, those are a sign of either bad oil or really beating the engine to death... like 7k rpm for 10 minutes or something... Honda crankshafts are among the strongest cranks in the industry ! So it should be ok.
rheyrhey
Oct 18, 2007 08:08 PM
Redwidow
Jun 9, 2006 08:51 AM
JDMFerio01
Jul 13, 2005 04:11 AM
poch915
May 18, 2005 01:31 AM
TegRaceR98
Nov 12, 2004 10:27 AM
