TPS code draw timing?
Old Dec 11, 2006 | 01:30 PM
88 rex's Avatar
Default TPS code draw timing?
If you throw the TPS code (forget the code off the top of my head), does it changing your timing and suck the power out of your car?
Old Dec 14, 2006 | 01:06 PM
88 rex's Avatar
Default Re: TPS code draw timing? (88 rex)
Any input appreciated.
Old Dec 14, 2006 | 11:16 PM
sexyrex's Avatar
may not change timing but may produce a lean condition (stumbling/hesitation), because the computer does not recieve the right signal telling it to add fuel as the throttle opens. you should eventually recieve an o2 sensor code if i am correct. also the tps is the only link from you to the engine.
Bh8teen
Aug 31, 2005 09:26 PM
civic_dork
Jul 3, 2005 07:40 AM
Red_Si
Aug 18, 2004 04:44 PM
