B18C swap in progress...which harness is which?
I have a '99 DX hatch, and just pulled the motor out of it. I've done searches on this topic, but can't find an exact answer for my question. I under stand that I need the 99-00si rear and driver's side mounts for it to bolt in correctly...but my question is with the harnesses. I have the Jdm B18. Now, the harness attached to the engine is for RHD..( obviously). There is another harness that goes from the ecu to that harness too, is that correct? so there are like 2 harnesses?
I 've been reading about it, and figure I can add wires for vtec and all that to the DX harness and then get a ECU jumper which should work, or a 99 EX or SI harness and ECU jumper and then connect it that way, or just , and this is what i'm not sure of... can i get a new harness for the ecu to the engine bay that the engine harness connects to? I'm getting so lost in all this and now i'm confused. Jerome Soh ( www.sohfast.com ) has a Wiring harness for a 94 -95 GSR for $200. Can i get that or is that for the actual engine itself?
let my know what to do about wires and stuff
thanks
thanks
so are u saying that u want to get a conversion harness? if so there are a couple of guys on this board that make those. all u need is the conversion from the OBDII to the OBDI dash harness, so that ur plugs match that of an OBDI ecu.
thanks
thanks
I feel your pain ...I'm also doing swap need help understanding some stuff...I have 98 civic Lx I'm putting in a b18c1 ...the engine came out of honda hatch back running ...so the engine is complete ..came with harness on engine but the one that's on engine is different from the one stock in my car ...when I pulled engine out of my car I left the harness hooked to car just pulled the engine out ...now I'm stuck cause Im not sure if I have to buy ecu and harness for the b18...if so how do I pick witch ecu and harness to get
In general with swaps, you can re use your engine harness that the car had before the swap, and add wiring to that harness for things such as VTEC. It might also require converting things like the distributor/alternator/fuel injectors.
Or, you can use the harness that’s on your engine, and convert your car to work with the engine harness.
Those are the two options and it just depends what year the B18C1 is off of, to determine if it’s worth using that engine harness, or just scrapping it and going with the engine harness your car had in it which would mean you stay with the OBD your car already is.
I prefer to use the engine harness that the engine has on it, and make the car work with the engine harness, but lots of people say to use the harness from the previous engine and modify it to make it work with the new engine.
luvmihatch
Jul 12, 2012 01:14 PM
jm2000turbo
Mar 29, 2012 07:00 AM
BOOSTEd2
13
Mar 28, 2011 04:56 PM
