hand brake light stays on when cold
Old Dec 11, 2006 | 11:33 AM
NAmodified's Avatar
Default hand brake light stays on when cold
hand brake light stays on when cold...
dont know why it does that, any suggestions?
Old Dec 11, 2006 | 12:23 PM
Perfectionist's Avatar
Default Re: hand brake light stays on when cold (NAmodified)
Is the level in the brake fluid reseviour low? (If so, it may indicate a leak or just worn out brake pads, so don't just fill it all the way up without checking that out). Or, parking brake is borderline out of adjustment or cable is hanging up.
Old Dec 11, 2006 | 01:40 PM
95 integra's Avatar
Default Re: hand brake light stays on when cold (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">Is the level in the brake fluid reseviour low? (If so, it may indicate a leak or just worn out brake pads, so don't just fill it all the way up without checking that out). Or, parking brake is borderline out of adjustment or cable is hanging up.</TD></TR></TABLE>
Exactly what he said , if the brake fluid is low, it likely means you need new pads.
Old Dec 11, 2006 | 08:59 PM
Red4drLSintegra's Avatar
Default Re: hand brake light stays on when cold (95 integra)
ive read it could be something to do with the brake fluid filter(ive heard there is one...)
My integra does it also..only on cold mornings..goes off after warming up..
and was on when i needed new brake pads and my rotors were warped
Old Dec 12, 2006 | 09:28 AM
NAmodified's Avatar
Default Re: hand brake light stays on when cold (Mommy2savannah51405)
my pads still have a little meat on them... i will check out the brake fluid tonight
Old Dec 12, 2006 | 11:19 AM
You may want to check this out when you get time...
http://www.tegger.com/hondafaq...e.pdf
The system may be similar enough to yours.
Old Dec 12, 2006 | 12:17 PM
silentdeath12886's Avatar
it is a typical integra problem. it happened to mine last year and again this year when it got cold. assuming the fluid level is good then just lift up the brake resevoir cap and pull it up then put it back and and screw it back on. presto. if you dont believe me try it first or do a search and that typically is the problem, i couldnt telly ou why i jsut know it works.
Old Dec 12, 2006 | 01:11 PM
red01teg's Avatar
Default Re: (silentdeath12886)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdeath12886 &raquo;</TD></TR><TR><TD CLASS="quote">it is a typical integra problem. it happened to mine last year and again this year when it got cold. assuming the fluid level is good then just lift up the brake resevoir cap and pull it up then put it back and and screw it back on. presto. if you dont believe me try it first or do a search and that typically is the problem, i couldnt telly ou why i jsut know it works.</TD></TR></TABLE>
true. just unscrew it and put it back on. it should go turn off.
Pabs626
Dec 9, 2007 05:02 PM
Jaydeep
Jul 27, 2004 08:00 AM
itr_dc2
Jul 12, 2004 10:22 AM
Tench
May 11, 2004 10:23 AM
SlowazzGSR
Jun 7, 2002 10:30 PM
