How do u Tighten the T-Belt ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elbowpunk »</TD></TR><TR><TD CLASS="quote">i have a 90 integra that my T-belt is popping over the cams... how do i tighten it ?</TD></TR></TABLE>
get a timing belt that fits
turn the motor until the belt is really tight on the exhaust side of the belt then loosen the tensioner bolt push up the tensioner and tighten it again while holding the tensioner as high as you can push it. and call it a day,.
Modified by 92redhatch at 12:45 PM 12/11/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch »</TD></TR><TR><TD CLASS="quote">turn the motor until the belt is really tight on the exhaust side of the belt then loosen the tensioner bolt push it up and tighten it again. and call it a day,.</TD></TR></TABLE>
push up what the belt ?
if the tbelt is skipping over teeth i would put a new timing belt first of all and chances are the tensior isnt far behind... loosen the 14mm on the time of the t belt cover and rotate engine counter clockwise and the retighten 14mm to tighten the belt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2daturbo »</TD></TR><TR><TD CLASS="quote">loosen the 14mm on the time of the t belt cover and rotate engine counter clockwise and the retighten 14mm to tighten the belt</TD></TR></TABLE>
