Engine Light. Please Help
I have a 1994 integra gs-r
I have 78000
The engine light was blinking for awhile then it would turn off. This only happened when i started it.
Now it is on all the time
Isn't there a button to shut it off after you do your own matence?
If so, Where is it?
Pictures might help also
Thanks
Justin
[Modified by raversi, 6:45 PM 5/11/2002]
I have 78000
If so, Where is it?
Thanks
Justin
From: You can be my wingman anytime...., Las Vegas, US
Is it you check engine light or Maintanance Required light?.....If it is maintanance required light, you can look under your steering column, and there is a small square button, just press and hold it for a couple seconds.....If its you CEL, you have to reset your ECU.
