civic EF HELP
Old Dec 11, 2006 | 05:59 AM
TMC_EF's Avatar
Default civic EF HELP
I NEED HELP MY EF IS AN AUTOMACTIC BUT I STILL YOU DA EMERGNECY WHEN I PARK BUT FOR A COUPLE WEEKS THE BRAKE LIGHT DOES NOT TURN OFF AND THE BRAKE IS NOT EVEN ON WHAT COULD IT BE HELP A.S.A.P
Old Dec 11, 2006 | 06:07 AM
cb07's Avatar
Default Re: civic EF HELP (TMC_EF)
What?
Did you mean:
When you pull the emergency brake the light doesn't go off? If so, is your emergency brake still on? If not, big deal. Check for shorts in the wires.
Old Dec 11, 2006 | 06:41 AM
Civiclized's Avatar
If its the e-brake light that stays on, check the little switch down in the console.
Old Dec 11, 2006 | 07:41 AM
dynamitezz's Avatar
Holy hell. Read your post three times now and I still can't understand, you have an auto EF but your emergency light is on?
Old Dec 11, 2006 | 07:52 AM
fireant's Avatar
Default Re: civic EF HELP (dynamitezz)
There is a little peice of plastic on the brake pedal that pushes a button...its probably borken off and the little button wont be pushed when you release the pedal.
Put a small nut and bolt in the hole so it will push the button when the brake pedal is released. Be sure to adjust the jam nuts on the brake pedal so it stops on its own before smashing the little button all the way.
Old Dec 11, 2006 | 08:56 AM
I CRX I's Avatar
be careful that your brakes dont go out, have them checked because my auto EF did the same right before my brakes went out on me, after i got the brakes fixed it turned off
Old Dec 12, 2006 | 05:51 AM
TMC_EF's Avatar
OK MY EMERGENCY LIGHT STAY ON WHEN I PULL IT AND IT STAYS ON
Old Dec 12, 2006 | 01:47 PM
Smokinsax's Avatar
The Boot
Default Re: (TMC_EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TMC_EF &raquo;</TD></TR><TR><TD CLASS="quote">OK MY EMERGENCY LIGHT STAY ON WHEN I PULL IT AND IT STAYS ON </TD></TR></TABLE>does your caps stay on too??
Old Dec 12, 2006 | 01:56 PM
slowman's Avatar
I took way too long
Default Re: (Smokinsax)
If I gathered the right information, when you release the e-brake, the 'BRAKE' light in the cluster still stays on, correct? If so, CHECK YOUR ******* BRAKE FLUID DIPSHIT.
Old Dec 12, 2006 | 10:02 PM
EF Durty MX's Avatar
Default Re: (slowman teh OG)
check brake fluid, mine stayed on for a while n i checked my brake fluid and it was low, most likely your problem.
Old Dec 12, 2006 | 10:34 PM
89efDUSTY's Avatar
Default Re: (EF Durty MX)
Brake Fluid x3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">does your caps stay on too?? </TD></TR></TABLE> hahaha
bigboyhonda425
Feb 3, 2012 09:54 PM
mayfly
Feb 15, 2009 01:14 PM
cfran55
Sep 9, 2008 06:13 AM
Catch 22
Feb 10, 2005 03:19 PM
stRtypR25
Jan 5, 2002 09:17 AM
