Ending my RHD conversion. Questions if anyone can answer them.
Ok so I used my JDM harness. What ecu should i use cause Im almost positive that all jdm cars are obd 1 if im not mistaken. Can i use my lsvtec ecu which is obd1?
Mm and last question is will my jdm harness for the car and everything plug into my usdm engine harness?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kirk@SyndromeAuto »</TD></TR><TR><TD CLASS="quote">Ok so I used my JDM harness. What ecu should i use cause Im almost positive that all jdm cars are obd 1 if im not mistaken. Can i use my lsvtec ecu which is obd1?
thanks</TD></TR></TABLE>
if you have obd1 ecu plugs then use an obd1 ecu.
jdm chassis harness will not plug into USDM engine harness. use a jdm engine harness.
ok so i just bought a harness. a ek harness its missing the map sensor plug? or maybe its the green one but its weird. anyways used all jdm harness and jdm engien harness
Hope i put everything back together right.
