Gear based timing retard VS multi-stage boost controller?
Old Dec 10, 2006 | 10:41 PM
Hondoctors's Avatar
Default Gear based timing retard VS multi-stage boost controller?
I know that when a FWD drag Honda is making 600+ whp, all that power is unusable in 1st, 2nd, and 3rd gear. I have a Neptune and I know that there is an option called gear based timing retard, and I want to know if there is any disadvantage to pulling timing with this feature at the full boost VS using a staged boost controller.
Old Dec 11, 2006 | 06:21 AM
HNLV's Avatar
X2.
Old Dec 11, 2006 | 06:33 AM
nowtype's Avatar
Default Re: (sqeezincheeser)
Pulling timing will increase EGTs. Pull enough timing and you will melt stuff. Get a progressive boost controller. It will be significantly safer.
Old Dec 11, 2006 | 08:58 AM
HRTuning's Avatar
Default Re: (nowtype)
Using a staged controller and timing retard can give you great results. The staged controller alone will also make a huge difference.
laziebun
Engine Management and Tuning
Jan 26, 2009 03:43 AM
StreetRacin101
Mid-Atlantic (Sales)
Jul 17, 2008 11:09 AM
StreetRacin101
May 18, 2008 03:50 PM
TurboHondaGuy
Nov 9, 2004 05:33 PM
pipes
Feb 20, 2004 09:19 AM
