TPS problem prob or what???
Okay so a couple hundred miles ago (maybe even thousand) my CEL came on and it threw a Throttle Position Sensor code. It went on once while I was driving, I then turned my car off and it never came back on. It threw the code in memory so i reset my ECU. It has yet to come on since. Should I forget about it, or is there probably an existing problem since it came on in the first place. COuld this be an ECU glitch??? Just need some info because I'm doing a FL to NY drive next week...Thanks
B16
B16
