Oil dip stick, where should the oil be?
Old Dec 10, 2006 | 09:00 PM
invisible's Avatar
Default Oil dip stick, where should the oil be?
i've always wondered this, where should the oil be at? Between the two dots, top dot, over the top dot..? The car is pretty much stock everything motor wise.
Old Dec 10, 2006 | 09:01 PM
MidwestSiR's Avatar
top dot.. in between is ok.. below the bottom dot you be in troubles yo
EX-T's Avatar
Default Re: Oil dip stick, where should the oil be? (Battle23)
On the top dot. The bottom dot indicates 1 quart low.
Old Dec 10, 2006 | 09:02 PM
invisible's Avatar
Default Re: Oil dip stick, where should the oil be? (EX-T)
Is there anything wrong with being a little above the top dot?
Old Dec 10, 2006 | 09:03 PM
MidwestSiR's Avatar
how much is a little?
2DoorBandit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Battle23 &raquo;</TD></TR><TR><TD CLASS="quote">Is there anything wrong with being a little above the top dot? </TD></TR></TABLE>
depends on how much alittle above is to you is
Old Dec 10, 2006 | 09:04 PM
EX-T's Avatar
Like a centimeter or so, you're fine but like an inch, I would drain some out!
Old Dec 10, 2006 | 09:05 PM
MidwestSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T &raquo;</TD></TR><TR><TD CLASS="quote">Like a centimeter or so, you're fine but like an inch, I would drain some out!</TD></TR></TABLE>
true words
Old Dec 10, 2006 | 09:07 PM
invisible's Avatar
Default Re: Oil dip stick, where should the oil be? (MidwestSiR)
It's just about a ~cm. I guess Im good to go.
Old Dec 10, 2006 | 09:08 PM
invisible's Avatar
What would happen if there's too much?
Old Dec 10, 2006 | 09:09 PM
EX-T's Avatar
If it's way too much it can cause it to leak oil.
Old Dec 10, 2006 | 09:11 PM
invisible's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T &raquo;</TD></TR><TR><TD CLASS="quote">If it's way too much it can cause it to leak oil.</TD></TR></TABLE>
ic, i've done it before and thought it would just burn off. never really thought it could cause a problem, but isn't leaking anywhere so i guess im lucky.
Old Dec 11, 2006 | 12:33 PM
dennis278's Avatar
your oil level can happilly stay within the middle of the two dots, i leave mine half way between the dots forever.
Old Dec 11, 2006 | 02:22 PM
Malakai's Avatar
if there is too much oil, it will build up too much pressure and ur seals can blow out.
Old Dec 11, 2006 | 02:28 PM
DFW's Avatar
DFW
Default Re: (Malakai)
causing it to leak?
Old Dec 11, 2006 | 02:30 PM
Malakai's Avatar
quite a bit.
Old Dec 11, 2006 | 02:42 PM
jtchinoy's Avatar
By quite a bit he means like a rainforest.
Old Dec 27, 2006 | 06:59 AM
TheAccordGuy's Avatar
Default Re: Oil dip stick, where should the oil be? (.Huey)
can too much oil cause vtec to be weak.
Old Dec 27, 2006 | 07:44 AM
Pr0ject93hb's Avatar
Default Re: Oil dip stick, where should the oil be? (TheAccordGuy)
yup, can also cause you to burn more oil and smoke out of your exhaust. my dad took his mazda to the dealiship (cause he gets free oil changes) and then over filled it like a quart and a half or something like that. and he had no power and was smoking white smoke like crazy. luckily he took it back before he fucked his seals up.
oh and i leave my oil right between the two dots...and actually thats where it should be. if you take your oil to honda to get changed thats where they fill it to. thats like perfect, but there is obviously nothing wrong with filling to the top dot.
Old Dec 27, 2006 | 07:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheAccordGuy &raquo;</TD></TR><TR><TD CLASS="quote">can too much oil cause vtec to be weak.</TD></TR></TABLE>
yes it wont hit as hard. too much oil causes the entire engine to bog. and of course it matters how much is too much oil.
Old Dec 27, 2006 | 08:14 AM
EJgsr's Avatar
Default Re: Oil dip stick, where should the oil be? (Pr0ject93hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0ject93hb &raquo;</TD></TR><TR><TD CLASS="quote">
yes it wont hit as hard. too much oil causes the entire engine to bog. and of course it matters how much is too much oil. </TD></TR></TABLE>
hhhhmmmm.. v-tec is an on and off switch... i will hit the same...
Old Dec 27, 2006 | 08:27 AM
Default Re: Oil dip stick, where should the oil be? (USDMej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 &raquo;</TD></TR><TR><TD CLASS="quote">hhhhmmmm.. v-tec is an on and off switch... i will hit the same...</TD></TR></TABLE>
you sure? i guess i could be wrong.
crazyguy
Sep 27, 2007 04:38 PM
Kid1320
10
Apr 16, 2004 09:55 PM
shinra
Feb 19, 2004 06:46 AM
RGoose18
Nov 10, 2003 02:33 AM
scrap1ngsr
Jun 6, 2003 06:25 PM
