lowering a car, your thoughts?
Old Dec 10, 2006 | 07:33 PM
hindsonher's Avatar
Default lowering a car, your thoughts?
my next step in my car is to lower it, i was thinking that i would go eibach prokit for about 1.3" drop and a camber kit to help with alignment for even tire wear. would this be the best route to go for a daily driven car?
I want a lowered look but with good suspension, and on a budget? what have you guys tried on your ride, what works what doesn't?
(99 teg)
Old Dec 10, 2006 | 07:47 PM
DraginTeg93's Avatar
Default Re: lowering a car, your thoughts? (hindsonher)
i am running Tein S Tech Springs and Tekico blue struts .. with a 2 inch drop . rides nice and handles good .. A nice clean drop
Old Dec 10, 2006 | 09:25 PM
R-Lug's Avatar
Default Re: lowering a car, your thoughts? (DraginTeg93)
For the back I threw a bunch of weights (from my bench press) in the trunk. Lowerd it a lot. I'm not so sure what to do to lower the front...
Old Dec 10, 2006 | 09:35 PM
TurboGS-R's Avatar
Default Re: lowering a car, your thoughts? (R-Lug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-Lug &raquo;</TD></TR><TR><TD CLASS="quote">For the back I threw a bunch of weights (from my bench press) in the trunk. Lowerd it a lot. I'm not so sure what to do to lower the front...</TD></TR></TABLE>
That's not funny.
Old Dec 10, 2006 | 10:35 PM
Marshmallowman's Avatar
iv got neuspeed race springs in mine, gave it a nice drop, about to include some koni yellow shocks up front and some mugens for the rear
Old Dec 10, 2006 | 11:32 PM
Blk-dc2's Avatar
Default Re: (Marshmallowman)
i got skunk2 coilovers and stock teg struts, rides good but i have 16" gabs so it sits just right....oh yeah they are on the lowest setting (left my friend and my car alone to lower it back to the height i had it at after coming from the shop, found it droped to the lowest setting and left it like that)...daily driven
Old Dec 11, 2006 | 01:58 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hindsonher &raquo;</TD></TR><TR><TD CLASS="quote">my next step in my car is to lower it, i was thinking that i would go eibach prokit for about 1.3" drop and a camber kit to help with alignment for even tire wear. would this be the best route to go for a daily driven car?
(99 teg) </TD></TR></TABLE>
Sounds like a decent street setup. You might also consider replacing the shocks if they have a ton of miles on them, since you'll have everything taken apart to do the srpings anyway. However, don't bother wasting money on a camber kit. Even lowered to flushed tires, I only had -2.2* of camber in the front, which is perfectly fine for the street. Besides, a replacement UCA type camber kit will further reduce what little fron suspension travel you'll have left after lowering, as the upper ball joint is taller.
efstile
Honda S2000
10
Oct 31, 2006 06:32 PM
Devo94ac
Oct 26, 2005 09:32 AM
barely4dr
Suspension & Brakes
Aug 8, 2005 01:54 PM
s2kDinesh
Honda S2000
10
Dec 21, 2004 05:02 PM
Hoffy
Mar 6, 2004 05:36 AM
