Honda S2000 Honda S2000
Toe issues with lowered AP1s
Old Oct 24, 2006 | 01:30 AM
efstile's Avatar
Default Toe issues with lowered AP1s
I desperatly want to lower my car, but i want to make sure it will help the car, not hurt it. I saw a couple threads on here stating that "lowering will make all S2000s handle worse because it throws off the toe" or something to that effect. I believe this was based off the lowering of an early Comptech car that was not done right. I was planning on some Bilstein pss9s. Let me hear you guys.
Old Oct 24, 2006 | 01:32 AM
efstile's Avatar
Default Re: Toe issues with lowered AP1s (efstile)
bump
Old Oct 24, 2006 | 01:32 PM
s2kdre's Avatar
alignment will fix that, but if u want it to handle good or better, ur gonna need tein flexes, or any coilover set up, i dont think springs are gonna do a better job, the only reason i went with just springs is because i dont drive that car hard around turns, so i wouldnt get full use out of a 1300 dollar suspension.
Old Oct 25, 2006 | 11:09 PM
efstile's Avatar
More Help Pease!
Old Oct 26, 2006 | 11:08 AM
evil vapor's Avatar
Default Re: Toe issues with lowered AP1s (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">alignment will fix that, but if u want it to handle good or better, ur gonna need tein flexes, or any coilover set up, i dont think springs are gonna do a better job, the only reason i went with just springs is because i dont drive that car hard around turns, so i wouldnt get full use out of a 1300 dollar suspension.</TD></TR></TABLE>
I would not replace the stock suspension with "any coilover set up." Tein Flexes or any budget coilover suit aesthetics over performance.
Depending on your available grip (tire choice) I would not lower the car beyond 1.5".
As far as I know, there's no toe issues when you lower the car if you get an alignment with the proper specifications. This car has some bump steer characteristics but that can be tuned out.
Old Oct 26, 2006 | 01:04 PM
SiRMike's Avatar
I just installed the KW V3's on my car. It handles great imo...but it takes a lot of playing with the damping and rebound adjustments to get it to the level that you like. I would recommend the KW V3's for an S2K owner...great coilvoer considering what you pay. Look into them.
Old Oct 26, 2006 | 07:36 PM
GEN2TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efstile &raquo;</TD></TR><TR><TD CLASS="quote">More Help Pease!</TD></TR></TABLE>
It's simple, a good coilover setup with an aligment and you'll be fine.
Old Oct 27, 2006 | 09:26 PM
Francesco's Avatar
tein flew isnt going to do anything but lower the car.
Old Oct 30, 2006 | 07:12 AM
WhiteAP1's Avatar
Default Re: Toe issues with lowered AP1s (Francesco)
Man, i dont know what sort of Tein flex kit u get where ure from, but my kit made a huge difference from stock. Turn in is 100 times better, the rear is a hell of a lot more stable, it handles better in the wet and my track times significantly increased. I agree there not as expensive as Zeal or Bilstien and are seen as an average coilover, but for a daily driver thats tracked every so often, i wouldnt go past them especailly bang for buck.
Old Oct 31, 2006 | 05:32 AM
Francesco's Avatar
Default Re: Toe issues with lowered AP1s (WhiteAP1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteAP1 &raquo;</TD></TR><TR><TD CLASS="quote">Man, i dont know what sort of Tein flex kit u get where ure from, but my kit made a huge difference from stock. Turn in is 100 times better, the rear is a hell of a lot more stable, it handles better in the wet and my track times significantly increased. I agree there not as expensive as Zeal or Bilstien and are seen as an average coilover, but for a daily driver thats tracked every so often, i wouldnt go past them especailly bang for buck. </TD></TR></TABLE>
Mine were great for the first 6 months, after that they became junk. Alot of people will agree with this.
Old Oct 31, 2006 | 06:32 PM
StinkyTofu's Avatar
Default Re: Toe issues with lowered AP1s (evil vapor)
No toe issues for me and i'm pretty slammed
cleanej2
Suspension & Brakes
May 6, 2008 11:21 PM
hindsonher
Dec 11, 2006 01:58 AM
Demonis
Honda Civic (2006 - 2015)
May 10, 2006 03:15 PM
Shake and Bake
Suspension & Brakes
17
Feb 25, 2006 06:24 PM
s2kDinesh
Honda S2000
10
Dec 21, 2004 05:02 PM
