88/89 door bolt onto 90 91 ? crx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N_A_is_best »</TD></TR><TR><TD CLASS="quote">yes they will fit seatbelts are another story u will have to use a bolt and washers on the top pillar to keep belts or just buy harness's</TD></TR></TABLE>
You also have to add a lower bolt on the d/s.
yes, the 88 (and 89 hf) doors fit on a 89-91 chassis. but not the other way around.
uh, i think the only seatbelt option is to retro fit the pillar mounted belts into the 90 chassis. you still have a bit of modification to be done. you cant put the door mounted belts on the 88 (and 89 hf) door.
no, it doesnt have to be HF.
the 89 HF doors are like all the 88 doors. for some reason only the HF's in 89 kept the same style doors. all other 89's are like the later.
https://honda-tech.com/zerothread?id=1456104 check this thread
KoRE
13
Mar 3, 2002 10:28 AM
