need HELP
ok i searched to check wats wrong with my car.
Now my car while driving will just die on me then i have to play with the gas pedal for it can keep on goin sometimes it will work and other times it wont. i drive 90DX.
Now i was told it may be my fuel filter replaced it then my relay then i check my pump now i noticed also it wasnt receiving any current now i ran a direct source of power to start the pump everytime i turn the key. Now eveything works i check the fuel filter and gas was goin through cuz i can tell becuase that i didnt tighten the bolts right.
Now eveything was finish i lower the car put eveything back together and when i turn the key it does the same. The car wont start it'll turn, and it does start for only a minute then i try to start the car and then just turns and repeats the whole thing.
PGMFI Main relays (fuel pump relay) are very well known for having intermittent issues. Might be the source of your problem. I believe it's the big black rectangular relay about 3 inches wide right under your steering column. It has something like 8 wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN-DA6 »</TD></TR><TR><TD CLASS="quote">it might be the cat. If the "cat" plug it will make your engine not run.</TD></TR></TABLE>
now how do u think that when im not useing a cat and my car runs fine?
