rear bumper turning black. why? HELP!
Old Dec 10, 2006 | 04:09 PM
xintegr's Avatar
Default rear bumper turning black. why? HELP!
My rear bumper turns black where the exhaust area is (right side).. Am i running rich or something.. my gsr has 101k on it. my oil does burn but thats only when im in vtec often, if not i dont kill that much oil. and my mpg is pretty good too. about 285 on a full tank.
Modified by xintegr at 1:04 AM 12/15/2006
Old Dec 10, 2006 | 04:36 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: rear bumper turning black. why? HELP! (xintegr)
just running rich, whats your motor setup?
Old Dec 10, 2006 | 05:05 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: rear bumper turning black. why? HELP! (It's*BOLO!!)
i second the opinion on running rich, carbon build up from running rich is somewhat normal and your total miles per tank aren't unusual, so it isn't anything to be overly concerned about
Old Dec 10, 2006 | 06:02 PM
tweekerz's Avatar
Default Re: rear bumper turning black. why? HELP! (GRAF-FITI)
Is your car white like mine? When I was open dp my driveway turned black. Now i've got the 3" and my bumper is hurtin
Old Dec 10, 2006 | 06:08 PM
xintegr's Avatar
Default Re: rear bumper turning black. why? HELP! (tweekerz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s*BOLO!! &raquo;</TD></TR><TR><TD CLASS="quote">just running rich, whats your motor setup?</TD></TR></TABLE>
just ihe. so how do i fix it? tune?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweekerz &raquo;</TD></TR><TR><TD CLASS="quote">Is your car white like mine? When I was open dp my driveway turned black. Now i've got the 3" and my bumper is hurtin </TD></TR></TABLE>
YES my car is white, it's really noticable and gets on my nerve.
this mechanic said it could be my piston rings and said itll cost 800. is he bs just to make money?
Old Dec 11, 2006 | 09:45 PM
xintegr's Avatar
bump for some answers
Old Dec 11, 2006 | 11:53 PM
SCIrONic's Avatar
How black are we talkin here? My tegs white, and after a full tank of gas only a little bit of black will show. If its not too much, and judging from your miles per tank, I'd say your engines running jsut fine and its normal for a white teg. I dont buy the piston ring story. Saying its your piston rings from the residue on your bumper is bs
Old Dec 11, 2006 | 11:56 PM
Fat Chick Magnet's Avatar
mine gets black always. but i wash her once a week so i clean it out good. black smoke means running rich aka dumping fuel. usually that smoke comes out when you hit vtec or downshift into a high rpm.
Old Dec 12, 2006 | 12:04 AM
99Geeezer's Avatar
Default Re: (xintegr)
excessive fuel pressure, plugged pcv, dirty air filter(doubt that yours a clogged) can cause rich mixtures. there are other system that can cause rich condition as well.
do you have any engine codes? maybe ect,o2 sensor.
is your ecu chipped?
Old Dec 13, 2006 | 08:52 AM
xintegr's Avatar
Default Re: (99Geeezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer &raquo;</TD></TR><TR><TD CLASS="quote">How black are we talkin here? My tegs white, and after a full tank of gas only a little bit of black will show. If its not too much, and judging from your miles per tank, I'd say your engines running jsut fine and its normal for a white teg. I dont buy the piston ring story. Saying its your piston rings from the residue on your bumper is bs SnowhiteLS</TD></TR></TABLE>
it turns more black than anyone would prefer trust me.. its not just a little.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer &raquo;</TD></TR><TR><TD CLASS="quote">excessive fuel pressure, plugged pcv, dirty air filter(doubt that yours a clogged) can cause rich mixtures. there are other system that can cause rich condition as well.
is your ecu chipped?</TD></TR></TABLE>
no i have no engine codes. ecu is stock.
bakertime
Aug 9, 2009 01:18 PM
nyturk
May 23, 2009 11:48 AM
raylude
May 28, 2006 04:50 PM
reza"
12
Sep 21, 2005 04:37 PM
StageOne
Mar 7, 2002 01:06 AM
