What kind of oil to use with boost?
Old Dec 10, 2006 | 02:26 PM
djtrini's Avatar
Default What kind of oil to use with boost?
Hey guys, just looking for a quick answer.
With boosted B series motors what would be the best grade of oil to run? this is on a daily driver.
Your help is greatly appreciated.
Thanks
Travis
Old Dec 10, 2006 | 02:28 PM
CustomX113's Avatar
Banned
i have been running 5w30 synthetic
Old Dec 10, 2006 | 02:30 PM
1baddturbosi's Avatar
Default Re: (95dxb18c1)
yep same here (mobil 1)
Old Dec 10, 2006 | 03:48 PM
djtrini's Avatar
what do you guys think about 5w40 or 10w40? one tuner here has recommended that grade?
Old Dec 10, 2006 | 05:17 PM
00BoostedGSR's Avatar
Default Re: (djtrini)
I use 5w30 reg. oil because my engine has use reg. oil since it's been of the lot.
Old Dec 10, 2006 | 05:18 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (00BoostedGSR)
i use royal purple 10w30
Old Dec 10, 2006 | 09:46 PM
djtrini's Avatar
hmm ok. So its a toss up between 5w30 and 10w30. Engine has fresh 81.5mm bore. new valvetrain, bottem end is built with new crank, rods and pistons. hp goal is in the 400whp mark.
Old Dec 10, 2006 | 09:52 PM
dunkd's Avatar
depends on what temperature range the car will be driven in.
Old Dec 10, 2006 | 10:04 PM
CRXdan's Avatar
Default Re: (dunkd)
5w30 since u live in ontario
Old Dec 10, 2006 | 10:09 PM
HatchEh2's Avatar
Default Re: (dunkd)
all depends on the weather outside... if its winter time, 5w-30 is best, that way cold starts are easier cuz the viscosity of the oil is lower but still a 30 weight when warmed up. you can use that all year round really. 10w-30 is fine when its warmer out.
if your motor is older, id stay away from synthetic, its soo thin that it finds leaks. and if your motor is really old.. then the synthetic will disolve the built up sludge and possible clog something in the oil system somewhere..
if the motor is new, its fine... AFTER BREAK IN. but once you use synthetic, ...you cant go back.
even on a new motor, i would only use a synthetic BLEND... cuz honda motors really arent ment for it... a friend of mine built an all motor poor man itr GSR.. Mobile 1 from day ONE... 66,000 miles later it smokes a bit and leaks a lil... synthetic is just too damn thin IMO..
Old Dec 11, 2006 | 06:19 PM
purpleh22's Avatar
Default Re: (HatchEh2)
I use Amsoil 20-50 synthetic racing oil and run 11 and 16 lbs boost. Amsoil 2000 synthetic racing oil has better load bearing and heat tolerance than regular oils. Synthetics can cost between $4 & $10+ per quart. Whatever you use, change it about every 1-2 K and use good filters (Hastings or other highly rated filters)
Old Dec 11, 2006 | 06:33 PM
aaronISthrowed's Avatar
Default Re: (purpleh22)
Mobil 1 10w-30
i run about 15 lbs of boost daily
Old Dec 11, 2006 | 06:37 PM
trini-gsr's Avatar
castrol gtx 10-30. running 10lbs daily.
Old Dec 11, 2006 | 06:46 PM
katoeh2o's Avatar
I use 15-40 delo. I live in hawaii so I don't worry about cold starts. I think I will start using 10-30 though. Oil with large viscosity ranges like 5-40 are not good can mess with turbo. cokeing
Hatcheh2 had some good info.
Old Dec 11, 2006 | 06:51 PM
dizzyek's Avatar
I live in ontario too I use 5w30 in the winter and 10w30 in the summer
I was using mobil 1 full sythetic 5w30 but the **** burned way to fast I was putting in a quart a week
Last oil change I tried Quaker state full sythetic 5w30 and I haven't burned a drop in two weeks.<<<<<its cheaper than mobil one also.
Old Dec 11, 2006 | 07:00 PM
Speed Infliction's Avatar
Default Re: (dizzyek)
what about filters? is oem the best you can use or what.
Old Dec 11, 2006 | 07:20 PM
dizzyek's Avatar
i use quaker state filters
Old Dec 11, 2006 | 07:31 PM
porsche997dc2's Avatar
I used oem oil filter and Shell 5w40 full synthetic from walmart. I do notice that the full synthetic 10w30 Mobil oil burn faster.
not2slo128's Avatar
honda filter ftw.
Old Dec 12, 2006 | 04:42 AM
redzcstandardhatch's Avatar
something different
Default Re: (not2slo128)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchEh2 &raquo;</TD></TR><TR><TD CLASS="quote">
even on a new motor, i would only use a synthetic BLEND... cuz honda motors really arent ment for it... a friend of mine built an all motor poor man itr GSR.. Mobile 1 from day ONE... 66,000 miles later it smokes a bit and leaks a lil... synthetic is just too damn thin IMO.. </TD></TR></TABLE>
i'm sure it didnt live an easy life...that can be a large part of a bit of smoking
Old Dec 12, 2006 | 06:15 AM
crucian's Avatar
Default Re: (redzcstandardhatch)
15w50 for me. Tried 5w30 and 10W30, but the oil always got too thin from heat. Look like I was pouring water when changing oil.
Old Dec 12, 2006 | 06:17 AM
B.'s Avatar
B.
400 HP Club
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">i use royal purple 10w30</TD></TR></TABLE>
labeldc5
15
Feb 26, 2008 01:08 AM
swimgurl
13
Sep 24, 2007 02:38 PM
Dr Miller
Aug 14, 2005 03:33 AM
gracedIntegra
Apr 20, 2005 07:44 AM
B00STeD
Aug 18, 2002 03:36 PM
