pain in the a#$ water leak inside car...
cannot figure this one out , i have water coming in from somewhere in the driver front near the fuse box . anybody have any ideas ? i had to rip out the carpet and toss it. ill try to post pics soon.
i did replace all the weather stripping , basically just pulled old of put new on , not sure if was supposed to do anything else.
This is the area where water seems to be coming from.. right around the bottom of the weather strip , but i see no sign of water from the weater stripping itself.
well... you can try pouring water over certain areas, working your way up the car. depending on where the leak is, it should only take a few seconds before you see water on the inside of the car.
hey guys , i found the leak finaly!!! it is the weather stripping ..i already changed this part once but i should have not bought it used. so anyway , now i need a new one , but i do not know where to find it and i dont wana go with the honda dealer because they over charge on everything. the part i need is the weather strip that is ONE THE DOOR not the one on the body. (driver side) if anybody knows a good company to buy this from please send me a link . all i have found is the body strip so far.
http://www.tasauto.com
They only deal with 94 + accords, just ask maybe they can find you something. Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swt_666 »</TD></TR><TR><TD CLASS="quote">thank you , they have exactly what i need
this should fix it </TD></TR></TABLE>
not a prob. I find everything OEM I need from them.
this should fix it </TD></TR></TABLE>not a prob. I find everything OEM I need from them.
glad you solved your isuue, as for buying parts, i do shop at TASauto and they deliver FAST. but they do overcharge try majestic honda they are a few bucks cheaper and they deliver maybe a day later.
thanx , yeah i did notice it was a bit expensive. im just ready to get it fixed so i can move on to the next project, it looks like the car sat a long time with water under the carpet so i have to scrape and sand the floor panel (front and back) then re'prime , paint and maybe put down some dynomat before i can put the new carpet in. FUN FUN FUN
dlenoxx
Dec 2, 2010 12:05 PM
