rubbing on suspension with this rim/tire combo?
Old May 11, 2002 | 05:31 AM
austrian type-R's Avatar
Default rubbing on suspension with this rim/tire combo?
Will I rub on the inner control arm or any other suspension parts when using 225/45/16 with 16x7.5 inch rim offset 42mm?
Old May 11, 2002 | 05:38 AM
Warren's Avatar
Wrong-Way Wang
Default Re: rubbing on suspension with this rim/tire combo? (austrian type-R)
That's almost surely not enough offset. At the minimum you'll rub the rear control arms, which is fine, as long as it doesn't dig into the sidewall.
Warren
Old May 11, 2002 | 05:49 AM
Default Re: rubbing on suspension with this rim/tire combo? (Warren)
No I donīt rub into the fender (sidewall), cause those are pulled in the front and rear about 1inch.
So, do you mean 42mm offset will rub against the suspension, right? Should I go for 30 or 35mm
Brandeezy1
Jun 20, 2012 04:04 PM
zc911
Mar 27, 2007 11:32 AM
DarkTeg94
Aug 27, 2004 01:50 PM
avs
Jun 11, 2003 09:19 PM
JDM DC2 R
Jan 23, 2002 08:05 AM
