Cleaning the pistons
Old Dec 10, 2006 | 10:59 AM
ZXRider's Avatar
Default Cleaning the pistons
As wierd as this question might sound, im going to ask anyway. I'm about to install my rebuilt cylinder head but I am having a hard time just putting the head on the block with the pistons being this filthy. I attempted to clean them up with MEK but it did not do much. I know that with most high mileage engines the pistons probably look like this but is there any other way I can clean them up a bit? Nothing too drastic tho since I want to have the head back on by tonight.
Thanks.
here is a picture for reference.
Old Dec 10, 2006 | 11:00 AM
pizzamanprelude's Avatar
Default Re: Cleaning the pistons (ZXRider)
dont put anything on them while there still in the engine
Old Dec 10, 2006 | 11:02 AM
ZXRider's Avatar
Default Re: Cleaning the pistons (pizzamanprelude)
I put a little MEK on a shop towl and tried to see if i can scrub some off, didn't do much so I stopped.
Your saying I should just put the head on like this? I can't pull the pistons off. My goal was to fix a bent valve in the head.
Can I atleast use my compresser with low PSI and blow some debries away?
Old Dec 10, 2006 | 11:07 AM
you can try that (the compressor) but when your done put a ring of grease around the cylinder wall and turn the crank manually, this will pick up all the crap that you miss (crap off the pistons) then clean the grease off. dont put anything on the pistons (chemical wise) because i' m assuming the sump is still full, if it is you might contaminate the oil or degrease the bores by accident
Old Dec 10, 2006 | 11:12 AM
ZXRider's Avatar
Well after I get the head back on and install the timing belt and adjust my valves and everything, the last thing I will do is change my oil with a fresh Mobil 1 5W30. Aside from that I don't think im going to try to clean them up anymore anyway, that carbon build up is cooked on there to the point that it would take probably days to just clean a little off.
I'll probably just use the compressor to blow out some debris and crap.
Old Dec 10, 2006 | 11:13 AM
preludeguy_92's Avatar
I wouldn't worry about how clean your pistons are. However this might be a good time to put some new rings on it.
Old Dec 10, 2006 | 11:23 AM
Default Re: Cleaning the pistons (preludeguy_92)
to be honest i've never cleaned pistons other than trying to free the rings from them, its more off a problem on FI engines, they dont like carbon build up
Old Dec 10, 2006 | 12:07 PM
lude98SH's Avatar
Couldnt you spray some seafoam on them, then change you oil ? This is just a thought im not sure if there could be any bad effects from that.
Old Dec 10, 2006 | 12:09 PM
PirateMcFred's Avatar
Laundry detergent seems to take that crud off ok. It works well on oil varnish too. I have also seen engines sit for quite a while with coolant pooled in the bore, and that loosens the carbon too (but it's not fast).
Old Dec 10, 2006 | 12:17 PM
InvaderTrax's Avatar
I've just been using steel wool, or in really baked on stuff, a wire brush
Old Dec 10, 2006 | 12:41 PM
Speedra500's Avatar
Default Re: (InvaderTrax)
it does look like you have a lot of carbon/junk build up on your pistons, If you're planning on modding and tuning in the future it would definitely be wise to clean those off, you really don't want alot of build up on pistons like that
Old Dec 10, 2006 | 12:56 PM
TheWalrus's Avatar
id worry more about cleaning the head gasket surface than the pistons. unless you plan on a turbo, id leave the buildup on the pistons, it increases CR a tiny bit but i really dont think it will hurt anything on a normal motor
Old Dec 10, 2006 | 01:38 PM
Simple_Sauce's Avatar
Out of curiosity, how many miles does your engine have on it.
Old Dec 10, 2006 | 03:07 PM
ZXRider's Avatar
Default Re: Cleaning the pistons (Simple_Sauce)
163,000 miles
Old Dec 10, 2006 | 03:13 PM
ethereal2pt2's Avatar
i wouldn't be so worried about that either. it doesn't seem like you have much on your pistons. it'll just go back to that way even if you do clean it once you get your car runnin. it looks like normal wear.
Longbow
21
Oct 23, 2010 12:41 PM
tomlinson619
Apr 15, 2006 03:26 AM
hondaeg8
Jan 6, 2004 05:08 PM
sikcrx80
Oct 28, 2003 05:41 PM
Integra91LS
Mar 30, 2002 08:49 PM
