b16a1
i have a question that i know eveyone has heard a million times i want to fit a tubo on my car its a civic coupe i put a b16a1 in it a year and i need more power now i want to end up with round 350-400 hp i wanna know if there is a way to do this without getting a complete kit is it possible for me to do it bit by bit but still drive the car around!!! i want a good strong turbo that will last
You cant ride around with half of a turbo kit on your car, just keep on saving your money and look till you find one you can afford
setting and meeting goals is just as rewarding as turboing your car! getting in a rush tears things up!
good luck
good luck
I think I know what he's asking, but I have a better route for you.
When fab'ing all of your intercooler piping, you don't have to leave it on the car. When you're done fitting and welding it, remove it, then put your car back together and drive it. And when you have all of your parts to make a final product, then bolt all of your parts onto your car at one time.
Installing a high flow fuel pump, larger injectors, wide band O2, fuel regulator, engine management onto your car isn't soooo bad since you can temporarily cut down the injector duty cycle so that it provides the same amount of fuel as the oem fuel system. However, it's just not toooo common to do this. I mean, you shouldn't temporarily modify/install anything unless you just had to.
It's just not toooo common for instance for someone to install an intercooler kit onto their car and wait until they get the rest of kit to be completely done.
Patience is the key! Take your time! If you end up never getting a turbo kit installed, then it just wasn't meant to be.
P.S.- Another good thing to do is to find someone that has the same car, and the same setup that you are wanting, and have them help you. This way, they will know exactly what to do as far as the installation of the kit is concerned, and will save you lots of time. Just a thought!
ok thanx for the info but here is anotherone u guys have heard i was driving my car around and pushed it a little when i could smell some oil and when i looked i found oil all over the bottom of the motor so hre is the next question shall i fix this problem or go for a b20setup cause i work at a scrapyard and we just got a crv b20 in. i just wana go fast and this is the third motor in 2 years and i aint even racing
AznInvasion
Nov 8, 2004 06:31 AM
