energy suspension question
Old Dec 10, 2006 | 09:47 AM
janz3n's Avatar
Default energy suspension question
is it just me or is there 2 missing bushings.. this is supposed to be a front end control arm set. i know theres one big and one small for each lower control arm but then that only leaves two left.
Modified by janz3n at 1:17 PM 12/10/2006
Modified by janz3n at 1:18 PM 12/10/2006
Old Dec 10, 2006 | 11:53 AM
janz3n's Avatar
Default Re: energy suspension question (janz3n)
i need to know this as soon as possible. there should be 8 bushings to a kit right?
Old Dec 10, 2006 | 12:21 PM
Crx Jimmy's Avatar
the piece of paper that comes with it, has all the part # and the #'s that are included in the kit. what dont you understand? the 4 on the bottom are for the upper control arm and the big one is for the shock I believe. Im pretty sure they make a separate lower control arm kit
Old Dec 10, 2006 | 12:25 PM
janz3n's Avatar
Default Re: energy suspension question (Crx Jimmy)
i want to buy this kit off someone thats why im asking.. i dont have these or a piece of paper. iv looked it up many times and there are no actual pictures of this set. its the whole upper and lower control arm set thats why i cant figure out why theres only 6 bushings. i know the two big ones are for the shock mounts but there should be two more for connecting the lca to the body right?
ok well if the 4 small ones are for the upper then its missing two bushings. i dont need the 4 uca bushings since my uca are new. im just going to go oem for the lca bushings.
Modified by janz3n at 1:37 PM 12/10/2006
Old Dec 10, 2006 | 03:11 PM
Rywire's Avatar
the other bushing comes with the shock/strut kit
Old Dec 10, 2006 | 05:38 PM
DA9_DAD's Avatar
Default Re: energy suspension question (droppedcrxsi)
why don't you try calling ES. they are local...they can give you the information, just won't sell you the item.
http://energysuspension.com/
Old Dec 10, 2006 | 07:22 PM
Rywire's Avatar
Default Re: energy suspension question (EFSS#17)
im correct, but I would call the guy at http://www.suspension.com he knows his ****
Old Dec 10, 2006 | 07:36 PM
sierrakilo's Avatar
I just received a complete master kit from ES yesterday. Here's the parts list for the Front End Control Arm Bushing Set: p/n16.3103
4 - 2271 lower control arm pivot bushings
2 - 15.10.243.39 .750"x.406"x2.038" sleeves
2 - 3281 lower control arm pivot bushings
4 - 3280 upper control arm pivot bushings
4 - 15.10.299.39 .750"x.406"x1.486" sleeves
Space Cadet
Suspension & Brakes
Oct 29, 2010 04:55 PM
bigG
Suspension & Brakes
Apr 21, 2010 03:39 PM
94vtirozguy
Apr 14, 2006 11:37 PM
SoulSurfer
Dec 10, 2002 10:45 AM
CRXBart
Apr 28, 2002 01:54 PM
