H2B guys, which intake manifold provides more firewall clearance, euro R or skunk2
Old Dec 10, 2006 | 08:54 AM
Bense's Avatar
Default H2B guys, which intake manifold provides more firewall clearance, euro R or skunk2
welp, as the title states, anyone know?
Old Dec 10, 2006 | 10:41 AM
SIXTY's Avatar
Default Re: H2B guys, which intake manifold provides more firewall clearance, euro R or skunk2 (Bense)
Are those two manifolds longer than the stock one? I know with my oem one i have plenty of firewall clearance, almost more than with a b-series.
Old Dec 10, 2006 | 02:22 PM
cpmike's Avatar
euror without a doubt, the skunk2 is HUGE compared to it, and jams against stuff even in a larger accord bay. the euror is tiny, looks like a stock d manifold.
Old Dec 10, 2006 | 05:54 PM
high_revs's Avatar
you have no firewall issues...you can take the manifold out with the head on the car....its cake....go with whichever you choose...
Old Dec 11, 2006 | 09:00 AM
skunked's Avatar
Default Re: (SB tuning)
With the QSD kit you have plenty of room for either manifold however the Skunk is definitly larger (runner length).
Old Dec 11, 2006 | 12:59 PM
ESP-net
Guest
Posts: n/a
Default Re: (skunked)
If clearance was an issue, and you wanted the skunk2 manifold... I believe you could cut down the Skunk2 manifold runners as much as 1/2" to 1" (where each runner is straight as possible) and re weld it...take some work and I am sure plenty of die grinder time to smooth out the inside...impossible no...
Old Dec 11, 2006 | 02:58 PM
skunked's Avatar
Default Re: (ESP-net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP-net &raquo;</TD></TR><TR><TD CLASS="quote">If clearance was an issue, and you wanted the skunk2 manifold... I believe you could cut down the Skunk2 manifold runners as much as 1/2" to 1" (where each runner is straight as possible) and re weld it...take some work and I am sure plenty of die grinder time to smooth out the inside...impossible no...</TD></TR></TABLE>
I'm sure this is possible.
Old Dec 11, 2006 | 03:03 PM
SIXTY's Avatar
Why are all the h22 manifolds extremely long? Will they not benefit from a short runner manifold like the victor x?
Old Dec 11, 2006 | 03:11 PM
ESP-net
Guest
Posts: n/a
Default Re: (SIXTY)
As far as I know which isn't much short runners are better for FI...and 250+ NA jobs...believe it or not honda was pretty smart with the stock H22A manifold...unless your pushing 220+ whp leave or modify the stock H22A manifold...I wouldn't be amazed from a direct intake manifold swap from Stock H22A to a Skunk2 if you lost power...all depends on the setup...
Old Dec 11, 2006 | 03:19 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP-net &raquo;</TD></TR><TR><TD CLASS="quote">As far as I know which isn't much short runners are better for FI...and 250+ NA jobs...believe it or not honda was pretty smart with the stock H22A manifold...unless your pushing 220+ whp leave or modify the stock H22A manifold...I wouldn't be amazed from a direct intake manifold swap from Stock H22A to a Skunk2 if you lost power...all depends on the setup...</TD></TR></TABLE>
I know someone that made 205whp on a stock internal longblock and with bolt on's and that Skunk2 manifold. I have always heard bad things about them, still do. It's kinda like the ITR manifold VS the VictorX, the Victor X does really good on top and that's why we have used it in Drag, wouldn't surprise me if it would do well on the H22 as well.
Old Dec 11, 2006 | 03:22 PM
SIXTY's Avatar
i noticed a pretty big difference when i switched from a type-r style manifold to a victor-x on my b motor, never dynoed it though, along with some cams i dropped four tenths. I am thinking about maybe trying to fabb something up for the H.
Old Dec 11, 2006 | 03:26 PM
ESP-net
Guest
Posts: n/a
Default Re: (SIXTY)
For experimental...I always wondered what a modded OBX intake manifold could do...different runner sizes etc....
Old Dec 11, 2006 | 03:27 PM
skunked's Avatar
Default Re: (SIXTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTY &raquo;</TD></TR><TR><TD CLASS="quote">i noticed a pretty big difference when i switched from a type-r style manifold to a victor-x on my b motor, never dynoed it though, along with some cams i dropped four tenths.</TD></TR></TABLE>
Same with us.
I know the JG sheetmetal intakes do pretty good too.
Old Dec 11, 2006 | 03:37 PM
SIXTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
Same with us.
I know the JG sheetmetal intakes do pretty good too. </TD></TR></TABLE>
This one is huge
Old Dec 11, 2006 | 03:42 PM
ESP-net
Guest
Posts: n/a
Default Re: (SIXTY)
Damn...whats a muffler doing on the intake? lol jk that setup is obviously what you call all out race...
From what I heard JGE manifolds do really well...they can make a special manifold to your certain specs and needs and for the money I believe it's not that bad of a deal...spend a lil bit more bypass the skunk2 and get a JGE...
Old Dec 11, 2006 | 06:53 PM
high_revs's Avatar
thats a fat sass intake manifold lol
Old Dec 14, 2006 | 08:29 AM
Bense's Avatar
arg I wish the euro R didn't require the modification to the injector area
Old Dec 14, 2006 | 08:40 AM
Turbogixxer's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">arg I wish the euro R didn't require the modification to the injector area</TD></TR></TABLE>
Oh, it is fun.
Old Dec 14, 2006 | 08:41 AM
Bense's Avatar
I can't find any where that explains it, it all points to 2point6's dead site.
Old Dec 14, 2006 | 08:45 AM
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">I can't find any where that explains it, it all points to 2point6's dead site.
Trace the gasket.
https://honda-tech.com/zerothread?id=1019001
Old Dec 14, 2006 | 10:22 AM
ESP-net
Guest
Posts: n/a
Default Re: (Turbogixxer)
Anyone know if the Euro R (Type S) manifold is longer then a normal JDM H22A?
Measure from where the flange meets the head to the farthest point back, if anyone has a Euro R...
Old Dec 14, 2006 | 10:30 AM
2fast4u831's Avatar
I'm really 2slow
looks like it is a bit longer
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Dec 15, 2006 | 02:24 AM
americ_ian's Avatar
damn
if i was botherd enough to drive round to a friends place, im sure i could do it
he has a euro R manifold on his JDM CD6 SIR accord with a blacktop h22a
il see what i can do tomorrow, you guys mind measurements in Centimeters as thats only what my measuring tape has got
Old Dec 15, 2006 | 12:05 PM
2.2EG's Avatar
damn that engine bay is dirty as expletive
Old Dec 15, 2006 | 12:06 PM
skunked's Avatar
Default Re: (2.2EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2EG &raquo;</TD></TR><TR><TD CLASS="quote">damn that engine bay is dirty as expletive </TD></TR></TABLE>
yes, somebody needds to clean their ****
