LOOKED EVERYWHERE, need help installing JDM SIDE MARKERS on DC2
Old Dec 10, 2006 | 01:54 AM
Kangolbrand's Avatar
Default LOOKED EVERYWHERE, need help installing JDM SIDE MARKERS on DC2
Does anyone have a template to go off when cutting? what tool should be used? what to do and what not to do? I try searching everwhere but all I found was egs... im sure dc2 have their sidemarkers placed different. Or anyone know where to get the fenders pre done aready for sale? pictures or anything right now well help, if i use a dremel or something... it seems like it well skip when using a disk and cut more than whats needed... making it look ugly. Thanks
Old Dec 10, 2006 | 03:41 AM
bg-33p's Avatar
Default Re: LOOKED EVERYWHERE, need help installing JDM SIDE MARKERS on DC2 (Kangolbrand)
On a jdm fender or usdm? hold on lemme try to pull up the how to thread..
edit: nm jdm and usdm would be the same huh? well i couldnt find the particular thread but i found one with the picture in it https://honda-tech.com/zerothread?id=1391460 ask patrickgsr94 for more details i remember him doing a write up
Old Dec 10, 2006 | 05:59 AM
JDM_DC4_Fanatic's Avatar
Password:JDM sells fenders with sidemarker holes cut out, or you can have them installed too. Also, they sell the fenders with sidemarkers, sockets and a pig tail to wire it up. check it out
http://www.passwordjdm.com/pro...D=215
Old Dec 10, 2006 | 06:18 AM
Folgers's Avatar
Default Re: LOOKED EVERYWHERE, need help installing JDM SIDE MARKERS on DC2 (JDM_DC4_Fanatic)
Should be in here.
https://honda-tech.com/zerothread/1782269
Old Dec 10, 2006 | 07:22 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Because I'm nice
This is for an EG, but the hole's dimensions are the same:
Placement on my car, I went by pictures of a JDM fender with the sidemarker removed, and closeup pics of the hole, so it's not exact but looks real enough to me:
Old Dec 10, 2006 | 12:25 PM
Ldc4S's Avatar
Default Re: (PatrickGSR94)
Old Dec 10, 2006 | 04:34 PM
thanks for the help everyone... does anybody know when passwordjdm well be gettting the fenders in stock again as its out of stock right now? If its awhile, I guess ill just cut my fenders.... what tools do you guys use? I want it to be as clean as possible. Thanks
Old Dec 10, 2006 | 04:52 PM
OMG THE GOGGLES's Avatar
Default Re: (Kangolbrand)
Dremel and nothing but. (multispeed dremel..not the **** *** single or dual speed ones)
Old Dec 10, 2006 | 08:11 PM
Community Builder
Dremel sucks for cutting sidemarker holes, I know because I used it on several different cars. Get either a hand-operated metal nibbler from Radio Shack, or a pneumatic nibbler if you have compressed air. It's alot quicker, neater, easier to stay accurate, and alot safer and quieter than using those brittle cut-off wheels.
Old Dec 10, 2006 | 09:12 PM
Jay J's Avatar
Prince of Zamunda
Mine's dead on to the nearest (1/100th of a MM), and I used a drill, and dremel..drill 4 holes, then cut...
Measure 10 times, cut once...
Old Dec 11, 2006 | 05:13 AM
LsHoney84's Avatar
Default Re: LOOKED EVERYWHERE, need help installing JDM SIDE MARKERS on DC2 (teggysue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggysue &raquo;</TD></TR><TR><TD CLASS="quote">
edit: nm jdm and usdm would be the same huh? well i couldnt find the particular thread but i found one with the picture in it https://honda-tech.com/zerothread?id=1391460 ask patrickgsr94 for more details i remember him doing a write up</TD></TR></TABLE>
id like to see the write up
Hiroshima_VTi-S
Aug 19, 2007 06:28 PM
CrazyHondaBoy
Dec 16, 2003 08:41 PM
CrazyHondaBoy
Dec 16, 2003 07:14 PM
