Will a b18a1 head fit on a B20b long block?
Old Dec 9, 2006 | 08:25 PM
89ef-b18a1's Avatar
Default Will a b18a1 head fit on a B20b long block?
I have a built ls head, i wanna put it on a b20 block for more ft/lbs.
Old Dec 9, 2006 | 08:26 PM
.Manny.'s Avatar
Touching My Member
Default Re: Will a b18a1 head fit on a B20b long block? (89ef-b18a1)
im pretty sure you can. doesnt the b20 have a ls head on there to begin with. just different cams and intake manifold. correct me if i'm wrong please
Old Dec 9, 2006 | 08:40 PM
89ef-b18a1's Avatar
Default Re: Will a b18a1 head fit on a B20b long block? (90_EF_Si)
can a b20 use the same ecu and wire harness as the ls? in a 89 ef?
Old Dec 9, 2006 | 08:44 PM
89ef-b18a1's Avatar
I know the saying b-series fit all b-series?
Old Dec 9, 2006 | 11:32 PM
justseeingifitistaken's Avatar
yes as long as you have the right obd for your setup...ie 89 ef is an obd0 setup so use an obd ls setup for wiring ecu....very straight forward....and yes the b18a/b and b20 head are the same casting except for one head but regardless it is all interchangeable
Old Dec 9, 2006 | 11:41 PM
Default Re: Will a b18a1 head fit on a B20b long block? (hondaJDMimports)
you can convert to obd1/2 as well i dont mean to confuse you and say only obd0.....that is all up to you and your budget
kaduku
15
Jul 3, 2009 07:54 AM
Damills
Mar 10, 2009 11:32 AM
project kingLS
Dec 10, 2006 08:00 PM
eRACING
Sep 18, 2003 03:16 PM
Acura_I-RS
Jul 7, 2002 03:40 PM
