SIR Bumper Pole Relay???
What is the Honda Part Number for the parking pole [aka bumper pole] Relay that is installed on the 94-97 Honda Accord SiR ???
Please Provide Link to this Question for Verification...
i would suggest buying a civic pole harness and adapting it to the accord, i dont really know where you can find the part number for that, every bumper pole ive seen for sale was only the switch w/ wires and the pole unit itself..
Is There a Relay on Bumper Poles???
Is the Black Timer Box... a Timer or a Relay...
Sorry I Dont Trust Ebays Answer, I Just Need Confermation...
or
<FONT COLOR="red">Ebays Answer below</FONT>
There is a Switch, Wire Harness, Timer and Pole Unit...
It extends and retracts the pole at the push of a button. The black box is a Timer that shuts power when the pole is fully extended or retracted.
Easy to install harness. One 12 Volt feed and One Ignition feed. It plugs straight in to the factory fuse box and then just connect the Earth. The timer can be tied under the dash.
There are two wires that need to be run to the pole. Yellow/White and Yellow/Red. They will match the colours on the pole.
The Black Box is in Question Below that Seems to be Wrapped in Tape...
The Question is~> Relay or Timer...
or
Ok~ I Just Confirmed the Part is Called Time Delay Relay...
Does ANYONE know Where or How I can Get the Part Number???
Does Anyone Have an Accord SIR Bumper Pole Just Laying Around that You Can Just Post That Part Number???
Is There a Web Site or a Link for Honda Parts that Deal with Part Number Search???
We Almost Got this Question Solved... With Your Help We Can Solve this Mystery...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLUTCH*1 »</TD></TR><TR><TD CLASS="quote">Please Help
Someone here has to Know a Site
where I can Source Honda Part Numbers...
WTF is a part number gonna do for you?? Its not like you're gonna walk into honda and be able to order that part.
</TD></TR></TABLE>WTF is a part number gonna do for you?? Its not like you're gonna walk into honda and be able to order that part.
Its Just a Honda-Tech Question...
http://www.jdmchat.com/showthread.php?t=2279
Im Surprised No One Here Knows... :VerySad:
where I can Source Archived Honda Part Numbers
The Bumper Pole is a Device that Should be Attached on the Front Bumper Oppisite Side of the Driver.
This Device Should Raise up and down like an Atenna so the Driver can use the Pole as a Referance so he can Park while using the pole to see how close the Bumper is to the Object In Front of him...
The First Time I seen one was in the Late 70s so Its not a New Idea...
So What Website has Archived Honda Part Numbers???
Simple Question... Im Not Gonna Make It Hard for You Guys here at Honda-Tech.
The Question is....
What Website, Online Shop or Fourm is Used to Access Honda Part Numbers???
Please Answer with a Link.
Thankyou...
The Question is....
Thankyou...
The problem you're running into is that most Accord drivers don't care for bumper poles. In fact, many of us here could care less about JDM gadgets.
I think it's already apparent that we don't know the part number you're looking for, which is partly due to the fact that our sources for part numbers are for North American cars only.
there is absolutely no difference between honda pole relays, so listing that its for an sir does you no good. i have my relay installed in my car therefore i wont be able to get you a number, but here is an ebay seller that i got my relay from, just tell him you need a honda bumper pole relay and he'll know what your looking for
jdm_imports_usa
jdm_imports_usa
cb95spd
Mar 27, 2009 07:26 PM
alscrx
Mar 30, 2008 08:18 PM
