i am throwing a code which one is it?
Old Dec 9, 2006 | 11:56 AM
EF9 JAMS!!!'s Avatar
Default i am throwing a code which one is it?
as title states. the little light has indicated to me that i am throwing code 17. any info on what it is and how to fix it would be apprectiated!
Thanks
Old Dec 9, 2006 | 12:05 PM
Default Re: i am throwing a code which one is it? (hatch91JDM)
also i have a std. motor si tranny stock ecu that came with the car. have had no swapp-age done so, yeah. obdo, dual mutli-port. i have searched says it has something to do with the speed sensor. my speedo cable is busted, but i don't know about my speed sensor. how does this work?
Old Dec 9, 2006 | 12:29 PM
janz3n's Avatar
look at the faq thread.. theres code troubleshooting.
Old Dec 9, 2006 | 12:37 PM
JandMmotorsports's Avatar
Default Re: i am throwing a code which one is it? (janz3n)
speed sensor check and replace
Old Dec 9, 2006 | 09:34 PM
Default Re: i am throwing a code which one is it? (JandMmotorsports)
how do i check/replace this part....is it expensive?
Old Dec 10, 2006 | 07:34 AM
colnago's Avatar
If your sppedo cable is broken that is your problem. It will throw code 17-vss speed sensor. The gauge cluster produces the signal from the speedo cable turning. No cable no signal.
good luck, colnago
Old Dec 10, 2006 | 08:00 AM
Default Re: i am throwing a code which one is it? (colnago)
well i have had the speedo cable break before and replaced it but never threw a code.
Old Dec 10, 2006 | 08:10 AM
colnago's Avatar
don't know why, but when the cable turns the speedometer cluster in dash produces a signal for every so many turns that the ecu will detect. I have had electronic parts on my car go bad and never receive a cel.
Old Dec 10, 2006 | 10:26 AM
trrbl1bmx's Avatar
replace cable! no more what if's!
SiR_Injected
Oct 21, 2007 07:24 AM
HT Chaplain
Oct 25, 2006 08:26 PM
90AcuraIntegra04
Aug 7, 2005 05:04 PM
csp88crx
Jul 11, 2002 08:07 PM
