Entire fuel injection system question/answer
Old Dec 9, 2006 | 08:38 AM
GolfIVTyBiggums's Avatar
Default Entire fuel injection system question/answer
First of all I must say thank you for looking at my post. My DA is running a code 16, which by reliable sources mean fuel injectors. First question, I noticed none of the other codes have much to do with fuel, could it be the fuel pump? I recently took apart my fuel rail (I know I am a newb, it made me feel cool), and I looked at my injectors, I thought for sure I found the problem. One of my injectors pintle caps was broken, but upon further research that doesn't mean anything. I went to a junkyard, and bought an injector off of a b20, however the connector is different on it. I am assuming because this is a OBDII car I got it off of. Are all OBDI connectors the same? Also, I don't think the problem is a electrical one, I am almost sure one of my injectors is bad, as the car seems to not be getting fuel in one cylinder. Is there a sure fire way to find out which one is not working? Or should I run it with a new one and switch them out one at a time? Also if my fuel pump were bad, what is a good way to test that? And finally, my code 16 has put my car in limp mode, which levies a 3.5k redline. After I fix the problem will it just go away after a reset? Thanks.
Old Dec 9, 2006 | 01:41 PM
Default Re: Entire fuel injection system question/answer (GolfIVTyBiggums)
Anyone? Anyone?
Old Dec 9, 2006 | 03:20 PM
bump for prime time...
Old Dec 9, 2006 | 07:43 PM
I see a lot of lookers but no takers, come on, this is a chance for a real know it all to impress us all.
Old Dec 9, 2006 | 07:48 PM
Boots's Avatar
if its a code 16 its one or more of your injectors..since the car is at least 14 years old id replace all the injectors with new ones..ones for that car
Old Dec 9, 2006 | 08:03 PM
Default Re: Entire fuel injection system question/answer (boots)
So code 16, invariably means fuel injectors? It couldn't indicate any other problem? Anyway, thanks for the response.
Old Dec 9, 2006 | 08:05 PM
Boots's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GolfIVTyBiggums &raquo;</TD></TR><TR><TD CLASS="quote">So code 16, invariably means fuel injectors? It couldn't indicate any other problem? Anyway, thanks for the response.</TD></TR></TABLE>
yea a code 16 is a fuel injector cut and dry...it could possibly indicate other problems but thats the code
Old Dec 10, 2006 | 07:24 AM
How do you suggest I get 4 new injectors? At oriellys/twilight zone they want about 90$ a piece, pretty sure I can get better than that.
Old Dec 10, 2006 | 12:06 PM
Boots's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GolfIVTyBiggums &raquo;</TD></TR><TR><TD CLASS="quote">How do you suggest I get 4 new injectors? At oriellys/twilight zone they want about 90$ a piece, pretty sure I can get better than that.</TD></TR></TABLE>
shop around and get the best deal
96Integraracer
Jun 29, 2007 05:37 AM
big juan
Oct 29, 2005 06:59 AM
RexedM3
Jul 5, 2004 11:46 AM
Splat
May 2, 2002 07:00 AM
