Compression!
Whoever in the hell that told you that you would LOSE compression with a turbo, needs to be shot.
You GAIN compression with a turbo. Hence the need for lower compression pistons, higher octane fuels and such.
Lose of compression from a turbo, definately not.
Maybe you mean do a compression test before boosting? Or the popular rumor that the RSX has too high of compression to boost high numbers.
Either way your not going to lose compression by adding a turbo.
Well thanks for the info. guys. I also have another question, that i also have an integra LS. And i know that the integra have higher compression then the base rsx, just that it only have 140 hp. Which would you guys think i should put the turbo on?
i would rather boost the base model rsx, leave the teg for a daily driver, the base model rsx has 9.8:1 compression, its a little high but i have seen people boost 6-16psi on the k20a3, but with the turbo u would need to get a k-pro also to tune it, good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miracle »</TD></TR><TR><TD CLASS="quote">Whoever in the hell that told you that you would LOSE compression with a turbo, needs to be shot.</TD></TR></TABLE> Amen to that
TehMoonRulz
May 16, 2005 01:15 PM
